2013 ecoboost noise maker
Started by brandont, September 26, 2014, 09:11:05 AM
brandont
I have a 2013 taurus sho and I keep seeing people referring to the "noise maker" what does this piece do? Is it something we need?
fess
It's on the left side of engine.  It directs intake noise towards the cabin.  No you don't need it.
If you decide to remove it you have to install a 2.5in hub and clamp to cover the hole,dont expect any kind of increased power or noise,replaced mine with a hotpipe from 4DRHTRD excellent quality and metal finish,compared to stock with rubber and plastic and prone for leaks overtime.
No, it's not needed.  It's a bit unsitely too.  I replaced mine widen I did my entire hotpipe set.  I had the ones available through 4DR black ceramic coated.
Pics are here:
http://www.ecoboostperformanceforum.com/index.php/topic,2248.msg32460.html#msg32460
Final appearance:
Quote from: BiGMaC on September 26, 2014, 11:19:39 AM
No, it's not needed.  It's a bit unsitely too.  I replaced mine when I did my entire hotpipe set.  I had the ones available through 4DR black ceramic coated.
Pics are here:
Final appearance:
Compare to Stock:
True SW... Any color you want!  Both setups are also VTA.... I used OEM dual electric ECM controlled BOVs, but a TIAL spring controlled like SW has (in the pipe in discussion) can also be made to work if you retain the rear factory BOV to prevent CELs.... Of course if you only replace the one pipe you'll want to keep the factory BOVs. Bpd did his in white PC and they look awesome.... I know there are pics here somewhere showing the noisemaker removed.... Check the current safety for meth users thread I think.
brandont
Ok sweet. So it doesn't change the way it sounds or anything?
I honestly did not notice a difference in sound with the SoundScreenTM glass that came with the stereo.
brandont
Quote from: BiGMaC on September 26, 2014, 12:02:24 PM
I won't bother with it then. I'm always looking for little things to do
