Yes, maybe with the MyCal, the stage 4/91 will be better. I think the stage 4/91 is relatively new and was not even available with the SCT when I got my tunes back in January.
I know there has been much discussion on this but when I got my tunes, I asked Rick lots of questions about differences between the tunes. Some he couldn't answer and had to go to Dan before he could get back to me. At that time, he told me that stage 4+ had higher boost (up to 14.5-15 PSI), advanced timing, and altered A/F ratio. It was also set up to hold the boost longer into the RPM range. He stressed that it was really designed for 94 octane but many used 93 and got along fine.
When I went from stage 3 to stage 4+, the most striking difference I found was at about 4000 RPM and higher. From a dig, launching at 1500 or so, I could not tell a huge difference. Both would break the tires loose for a second or so and chirp again on the 1-2 shift. However, from 4000 - 6500, the stage 4+ was crazy strong compared with stage 3. Overall drivability was smoother and transmission behavior was more refined after about 100 miles or so.
Just my 2 cents....
