It says 87 but.....
Started by vforrest, June 04, 2014, 11:06:30 PM
vforrest
Just picked up my first Ford in years a 2014 SHO non-PP but has everything else on it so I'm learning something about the tech everyday.  My question is all of the performance numbers HP and MPG have an asterisk that says they were based upon premium fuel.  Yet the owners manual says 87 octane is fine but you'll get better performance with premium but no details.  The dealer gave me the car with a full tank of gas and it too was 87 octane.
So this is my company car and I'll put 40K a year on it for four years before the next one and I'm coming out of a very fun Infiniti EX35 AWD that was a blast but needed premium fuel.  I'm looking forward to regular 87 octane but I'm then curious how close to the 25 mpg. estimate will I get cruising @ 72 mph.
At 2000 miles I'll try five tanks of mid-grade and compare the numbers and then I'll try five tanks of premium.   Has anyone done this before and save me the research?
Thanks for your thoughts  and opinions.
jayskycj
I have personally seen a slight decrease in mpg using 87, however price still made 87 cheaper. I noticed a power difference too. Even on a stage 4 lms tune I get close to 25 highway.
2010 LMS Mycal 4X3Bar with K&N typhoon, 170 tstat, 534 plugs gapped .030, PPE Downpipes, magnaflow X Pipe and stock mufflers. Eibach Springs and Michelin Pilot Sport A/S 3.
Josephm
Why get a sports sedan if you plan on running 87?   I understand the fun part but you got to pay to play
12' Flex EB
Unleashed X4
3rd Cat delete
wasinger3000
I'd rather just spend the $5-10 more per tank to have more power available. That and it's better for the engine.
Sent using smoke signals.
13' GTCS, will be missed.
Welcome to the community, and congrats on your ride of choice!
As long as you trust the 87 octane fuel you are putting into the engine, you should be fine with it.  Since the SHO is turbocharged, detonation is more of an issue )even with modern engine management) than it would be in a naturally aspirated vehicle.  In our area, we have had bouts of poor gasoline quality (comparing same station, different times).  If ethanol is being added to your gas, you may actually be BELOW 87 in reality, which you absolutely don't want.  89 gives you that cushion of safety if you do not know the quality of gas being pumped in.  Thus, 93 is recommended for best performance, mpg, and reliability.  IF you drive gently, 87 should be fine.  If you are a leadfoot, 93 is your best choice.  91 if 93 not available in your area.
If/when you decide to tune your SHO, you will likely see noticeable improvements in mpg (no matter the grade of gasoline) and performance.  Livernois Motorsports and Unleashed Tuning are your top 2 options in this area, and based on reports so far, you will be very pleased with either choice.
J-Will
If fuel is a problem when modding (and it seems to be) then I would not feel comfortable putting anything less than mid grade.
3-bar
SP-542 plugs w/ GH gap
For years and years I put 87 ontane in my old explorer until the car would not start,changed the gas pump and could not believe all the s,,,t in the filter
Txstrmhntr
Welcome to the community!
I'm sure you will enjoy the SHO no matter if you remain stock or tuned/modified. It is a truly fun and fantastic car.
With that being said IMHO 87 octane is a poor choice of fuel. I have owned a force inducted vehicle since about the time I started driving (17 years). And I have always used premium fuel in them. For states that it is acceptable but premium is recommended. Around here premium is 30¢ more per gallon than 87. That works out to around $5-6 dollars per fill up. In most places that's less than a pack of smokes. Well worth the cost to ensure your car is performing safely and reliably at the power levels it was designed for.
Sent from my XT1080 using Tapatalk
OLD
2013 Taurus SHO with PP, LET Tuned, ATP+2 Turbos ,PPE Hotpipes, PPE off road DP's,  Alky control methanol injection
NEW-- 2016 Kona Blue Fiesta ST, Stock(not for long)
QwikSHO
a SHO as a complany car?
must be nice.
J-Will
Quote from: QwikSHO on June 05, 2014, 11:24:13 AM
must be nice.
I assume he owns the company- like a Realtor or consultant.
3-bar
I might put 87 octane in it with a stock tune if I was going on a road trip on flat low altitude roads, anything other that and I wouldn't run anything other than premium.
You have a twin turbo DI high compression motor, too many things to go bad, I'd rather have the safety margin of the higher octane. These cars respond amazingly to octane differences and will pull massive amounts of timing on 87 octane to stop the knock. FYI in the F150 world it has been noted that quite a few trucks have blown their motor running 87 octane.
This octane issue is one of the reasons why I'm such a huge proponent of running e85 mixture. Run 14 gal e10 91/89/87 and 5 gal E85. I guess you could cheap on out on 87 and put in some e85 to make up for the difference.
http://www.intercepteft.com/calc.html
87 Octane mix
19.00 gallons
91.7 octane
29.7% ethanol (or E30)
91 Octane mix
19.00 gallons
94.7 octane
93 Octane mix
19.00 gallons
96.2 octane
On a stock tune I would be you'd see quite a bit of HP increase between the mixes as the ECU will add timing naturally.
ShoBoat
Quote from: 4DRHTRD on June 05, 2014, 12:59:03 PM
87 Octane mix
19.00 gallons
91.7 octane
91 Octane mix
19.00 gallons
94.7 octane
93 Octane mix
19.00 gallons
96.2 octane
Question, will the stock fuel system handle the 30% mix? The max on the fill tube says 10% max?
2012 Pearl White CTS-V Stock
Yes it's been verified a ton
goblues38
18 gallons of fuel @ .40¢ extra a gallon for premium = $7.20
To me its crazy to let $7.20 stand in the way of extra performance and better gas millage
2013 SHO w/pp
     -35% tint
     -relay wired to have parking lights on any time car is running
     -SCTx4 (Torrie Tune)
2014 Explorer Sport
J-Will
Quote from: goblues38 on June 05, 2014, 02:08:45 PM
That's a bit narrow sighted math over the course of 40k miles. So I see the reason behind the question, however I use the highest grade I can too.
3-bar
