Started by panther427, May 16, 2014, 11:16:00 PM
Quote from: panther427 on May 17, 2014, 08:38:39 AMThanks sho man. I checked them versus stock size but not against other known tires sizes that fit.
Quote from: shoman04 on May 17, 2014, 06:41:19 PMQuote from: panther427 on May 17, 2014, 08:38:39 AMThanks sho man. I checked them versus stock size but not against other known tires sizes that fit. You welcome. I'm down here in the south so I don't need winter tires so I have set for DD(245X40X20) and track (275x40x20) tires because that added 1.20 inch to put just a little more rubber to the ground at the drag strip/auto-cross.
Quote from: DRII on May 17, 2014, 08:45:44 PMQuote from: shoman04 on May 17, 2014, 06:41:19 PMQuote from: panther427 on May 17, 2014, 08:38:39 AMThanks sho man. I checked them versus stock size but not against other known tires sizes that fit. You welcome. I'm down here in the south so I don't need winter tires so I have set for DD(245X40X20) and track (275x40x20) tires because that added 1.20 inch to put just a little more rubber to the ground at the drag strip/auto-cross.would you use the 275s as a DD tire?if not, why not?
