a lot of tire noise after rotation and balance!
Started by MeanKS, March 08, 2014, 07:33:49 PM
SHODYOU
I def have more noise after my last rotation... Hankook v12
But I drove it a lot of miles for work before rotating, like 15k... so im sure its uneven wear front/rear. It has subsided some since but still louder than before. Still smooth and grippy tho.
2011 SHO - Tux Blk/blk int, 402B, acc, nav, multicontour, 20s. LMS 4X MyCal, 3bar MAP, K&N Typhoon, 170* t-stat, SP534's @ 30, Stainless Works catless DPs, Corsa catback, H&R sports, 5/16 front-7/16 rear spacer, 255/35 Hankook V12s, Lamin-X/PlastiDip
2004 Mustang GT - Comp Orange, Boss block/3.80 stroker 327", Foxlake TFS', Hellion turbo, blah blah
Brucelinc
What rotation method are you guys using...just front to back or the modified X where you move the rears straight to the front and cross the fronts when you move them to the rear?
MeanKS
Well my problem turned out to be a wheel bearing failure.  had nothing to do with the alignment or chopped tires.
its just seemed very strange that the roar occured right after the tire rotation and balance???
i assume a wheel bearing fails overtime and not just all of a sudden.
if any of you are hearing noises when you turn the steering wheel slightly to the left or right (along with the discussed tire roar), i would have the dealer check the bearings.  mine was covered under warranty...
MKS-EB...
SHODYOU
Quote from: Brucelinc on April 08, 2014, 09:23:15 AM
Well mine are directional so I have no choice but the front/rear method.
I usually rotate every oil change, ~5k miles... just got busy and weather was godawful so it got pushed back this time
