corsa exhaust self installation
Started by REDSHOCGO, January 20, 2014, 07:05:20 PM
REDSHOCGO
So I'm about to pull the trigger on the corsa exhaust and am wondering how easy the install will be with.myself doing the job using a.Jack and some Jack stands. Has anyone installed on their own?
2010 Red Candy Sho 402a option non/pp w/unleashed tune,3 bar map, k & N CAI, Corsa catback exhaust, tints 35% front 20% back vta conversion,plastidipped front grill (matteblack), Curva Concept C7 wheels w/20" toyo proxes +4 and Sony Xperia z running torque pro
2011 Sonata 2.0T Limited tinted
2007 Pontiac G6 GTP cpe w/crab intake,Led sequential taillights, custom exhaust(now gone)
I helped a mechanic buddy put a direct fit Magnaflow on my Fusion.  If it's anything like that you shouldn't have any trouble.  Don't tighten the clamps as you go.  Just snug them up so you can tweak it a little for alignment.  Then crank them all tight.
jack er up ....put her on stands and have a friend help you .....  easy install .... as stated by DJ snug clamps but dont tighten fully till its all on . OH   ..... and a six pack wouldnt hurt either ......
REDSHOCGO
We'll trigger pulled with 2 day shipping definitely will solicit the help of a friend with a 6 pack..can't wait to get it. Next will be the cai and probably some tint
Sounds good!  Let us know how it goes.
REDSHOCGO
Will do.probably won't get to it till Saturday dependant on are bipolar weather. I don't have a heated garage so Ya. Have some space heaters though
Space heaters and cold beer!  Yeehaw!
REDSHOCGO
Try to do a "how to" series on it.  :please: Then folks won't have some of the concerns you did
I did myself, not to hard at all. Of coarse a extra set hands will help. System is pretty straight forward and requires basic tools. The hardest part I had was getting the 1st section that bolts flanges to slip into the 2nd section. They are both 2 pipe sections, I put these together out from under the car as it was just much easier. Everything was a breeze. Only about a 1.5hr job.
REDSHOCGO
Just an update on this I wound up taking it to the shop to install . Had to squeeze underneath the  car because the jacks only went so high and could not get the nuts off to disconnect as it was around 19 degrees and my garage is not heated I decided it wasn't worth the fight
REDSHOCGO
Definitely. Love the exhaust note especially when at wot
Quote from: REDSHOCGO on January 28, 2014, 10:47:24 PM
Excellent..... do you notice any change at idle?
