- Full Member
- Newb
- Logged
By going with a wider rim, your tire sidewalls are probably flexing out slightly and drawing the tread in towards the tire a little (\_/ vs l_l ). Combine that with the very slight change in wheel orientation and maybe that is enough for you to notice. You could step up a size or two in tires to help fill it out (and give you a bigger contact patch). Look at the tire specs for the desired tire and you can compare it to the stock application. There are lots of comparison calculators online. Most tire specs will also give you a max and min rim width and a recommended. Personally, I tend to stick towards the minimum end. This gives the tire a little bit bigger look.
Lucy Ford 2015 Ruby Red Tinted Clearcoat Metallic, GearHead AO Performance Tuned - SCT X4, GearHead Intercooler, 3-Bar MAP, EPP Hot Pipes (Plum Crazy), EPP Dual Intake (Plum Crazy), AD Mounts, MSD Coils, JLT Oil Separator, 160 Thermostat, Ortiz Performance Battery Hold Down (Plum Crazy), Hellcat LPFP, 255/45R20 DSW06 Plus, Sync3 Conversion, CYANLabs Syn3, FMods, Jail Broke APIM, Infinity Kappa Speakers, Speaker Baffles, Whelen POV Response Package - (Inner Edge FST, Inner Edge RST, Sidekick, Tracer, LINV2, IONV3, HHS 200W, Howler 200W), Z-Flash, Full LED Swap, Drive Bright DRL Kit, Drive Bright Puddle Light Kit, Ford Sunroof Visor, Window Chrome Delete, OSRAM XENARC Night Breaker Laser, FORScan, OBDLink, Ford Cargo Organizer
