- RotM Winner
- Elite Member
- Boosted
- Logged
Hell yeah get after it! I just recently opened up my impact bar for some more air, and two sections of pipe were a bit too long, causing unwanted bends in my 90° silicone elbow, and also extra tension in general to the y pipe. I blew a clamp to the y pipe yesterday. So after reducing the pipe length in two sections, it went back together with less tension with plenty of silicone over the pipe connections. It appears to be working even better than before but I'll need more than just a 3rd gear pull to verify it...but 14° below ambient is awesome.
