Started by My15SHO, June 29, 2020, 12:58:05 PM
Quote from: My15SHO on July 27, 2020, 01:58:25 PMI get the battery going dead and preventing starting, but after its started and running, why would the battery cause the issues i had? Am i too old school in thinking it runs off the alternator once started? That power is run thru the battery but does a bad battery not allow that? I suppose after it sitting in a bay for 6 weeks and its all put back together the battery could take a dump quick.
Quote from: ridered74 on July 28, 2020, 01:05:42 AMQuote from: My15SHO on July 27, 2020, 01:58:25 PMI get the battery going dead and preventing starting, but after its started and running, why would the battery cause the issues i had? Am i too old school in thinking it runs off the alternator once started? That power is run thru the battery but does a bad battery not allow that? I suppose after it sitting in a bay for 6 weeks and its all put back together the battery could take a dump quick.It does, but old school cars weren't as dependent on electronics as cars today are. If a bad battery causes voltage fluctuations it can effect pretty much every aspect of the car since almost everything is controlled by electronics in some way or another.
Quote from: My15SHO on August 07, 2020, 09:16:07 AMIm gonna look into it myself, is "bank 2" the front or back cylinder head, also will the vct connector be on the left or right side. I found some answers on an F150 Forum but our engines are sideways compared to theirs
Quote from: My15SHO on August 07, 2020, 08:37:10 AMI was told a transmission line wasnt tightened and leaking, they tightened it and topped it off. No more leaks overnight so i assume thats fixed. I had the car back for two days and it throws a P0020 code on the way to work, which happens to be the same code that i brought it in for back on June 20th. 7 weeks.....three visits.....right back where we started.
Quote from: My15SHO on August 08, 2020, 09:26:50 AMThanks for the info, so the million dollar question is if it is the wiring/plug that causes the code, is it just a split second voltage that sets the code and there is no "damage" being done? I reset the light with a scan tool and it hasnt come. back on yet. Is there any harm being done by faulty wiring to the engine and the timing?. Thanks a lot guys!
Quote from: My15SHO on August 08, 2020, 06:39:02 PMIs what we are talking about....this plug and sensor? Pics attached
