- RotM Winner
- Elite Member
- Boosted
- Logged
What kind of trans temps are you seeing? You didn't add a trans temp to the aux cooler is that what you're saying? I had to reread what you said, at first I thought you were saying you were seeing 100° down here like now your trans temp was down to 100° not the weather...but you meant the weather.
