American Muscle Dark Stainless 20x8.5 Wheels
Started by WhitePlatinumSHO, August 31, 2018, 04:24:23 PM
WhitePlatinumSHO
Finally got my new wheels mounted / installed. They fit perfectly but now I want to lower it.....
2016 Platinum White SHO
- Unleashed Tune & 3 Bar MAP
2010 Red Candy SHO - Gone but not forgotten
1997 Cobra Coupe - 659rwhp / 609rwtq
SM105K
Quote from: WhitePlatinumSHO on August 31, 2018, 04:24:23 PM
I would just level it. Looks good.
802SHO
I think that wheel design looks really good on our SHO's.  And I agree you should level it....after you lower it!!  😄
AJP turbo
They look good on the white...Yeah needs dropped down a bit
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
limited02
Looks great!  Next time you have the wheels off, could you please weight them?  I'm curious how much they compare to the Niche Targa's I'm about to put on.
WhitePlatinumSHO
Quote from: limited02 on August 31, 2018, 11:26:31 PM
In the box each wheel weighs 28lbs according to the tracking number....
limited02
Quote from: WhitePlatinumSHO on September 01, 2018, 07:32:50 PM
Thanks!  I weighted my Niche Targa's at 29lbs per wheel (20x8.5).  Depending on how they look on my MKS, I may switch to the AMRs down the road.
