Inconsistent boost
Started by arrivalblue, July 11, 2018, 05:54:09 PM
arrivalblue
Having issues with power. Car is monitored by a Livewire Ts+ Gauge. When going WOT sometimes it'll boost 8-9psi. Other times it'll struggle boosting past 3 or 4Psi. Car is stock besides drop in air filter and BOV to atmosphere. Car is a 13 MKS EcoBoost 75k Miles. Thanks guys.
AJP turbo
The 8-9 psi is ok but not 3-4...are you sure the vta ...since you have a livewire you could do some logs...id take a look at them for you....you could pm me your email and I could send you a config file and how I'd want you to log
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
arrivalblue
Yea I VTA'd them myself with the rubber caps. I truthfully am not sure how to even data log with it. My concern is possibly a sticking Diverter valve or maybe a bad turbo? It boosts well before it gets up to temp. Then it almost heat soaks? I'll pm you email
arrivalblue
Is boost dependent on gear in these cars?
I would check for a) loose hoses atop the intake manifold, b) failed orange seal at the BOVs, and c) loose/cracked turbo piping particularly where clamped.
arrivalblue
Will do! I've briefly looked for anything obvious hadn't seen anything but I'll double check those. Hit 8.9psi in 2nd gear pull this morning. Only to hit 3.44 the next pull. Strange stuff
Ueah it could be a wastegate actuator  (not usually heard of on the 3.5) or a tune problem (logical).  Datalogging will show if throttle  control is being applied properly.
arrivalblue
Yea I'll have to log it. It's super strange to me that it's not more consistent. Although I'm also used to Supercharged applications where it's not usually an issue.
arrivalblue
Stupid question but when I vented to atmosphere I used the rubber caps for like walkers and stuff. Apparently it cracked allowing air to escape. Would this cause the issue?
It should be noted to avoid Bootlegged items!  Z   :D
https://www.mcmaster.com/#40005k35/=1doph7o
arrivalblue
Haha does anyone VTA using something better?
Quote from: arrivalblue on July 12, 2018, 06:21:04 PM
Serious note Glad to hear you got her fixed pronto!  Z  :)
www.mcmaster.com makes some awesome Silicone/vinyl caps which work great in high heat applications.....
I believe its a 1" OD, 2" Inside Height! IIRC.
BTW Derfdog might still have some available!  Shoot him a PM.
arrivalblue
Haha yea so far it seems it has I'll be ordering those ones you linked I like how they don't taper probably sit lower better. I'll have to do some pulls to see if it's for sure the fix. I'll try to do some logs. Want to get everything right before I put the tune and stuff on that's been sitting for months
Wonder if derfdog has any left ...
