Cylinder compression
Started by StealBlueSho, February 03, 2018, 07:09:34 PM
The SHO Platform is quite stubborn and do not emit codes that easily!  :(
How many miles on your current oil change?
Does it also make that tapping noise with fresh oil?
Agreed with SHOdded above and could be related to the vct solenoids as with time they get dirty!
I think there are four vct solenoids IIRC!  Z
StealBlueSho
Filters? I use Motorcraft oil filters as they seem to work best....
Changed oil out about 500 miles ago or so...
Tapping persisted through the oil change. Again, no debris in the last oil or filter...
Maybe Topher is misreading my previous post? I have high flow catalytic converters on my downpipes... they don't filter much of anything...
StealBlueSho
FWIW went to go take a video.... noise is gone.... perhaps it's a loose component...
Not sure if it was something in the rotation assemblies it would be consistent....
Trying to trick ya eh?  Well, heres to hoping!
StealBlueSho
Wouldn't be a SHO if it didn't... at least something from the SHO heritage seems to persist!
Right Oil is Critical. Z
With engine oil used to operate the cam phasers, two aspects of preventative maintenance become even more critical. First, these new Police Interceptor engines MUST have the right weight-viscosity of engine oil. The PCM opens up valves to control the cam phasers based on the correct oil. Too heavy or too light and the cam phaser will over-react or under-react. The VCT phaser not responding correctly to the PCM will cause a DTC: an error in action versus expected cam advance or retard.
Exactly the same condition can occur with dirty oil, specifically oil that has depleted the anti-foam additives. Oil with tiny foam (air) bubbles is more compressible than oil with no foam. So, oil under pressure has to break these tiny bubbles before it can act as a true hydraulic fluid. That will cause a slight delay in the response of the cam phasers to the PCM command.
It won't be much of a delay, but the PCM again monitors actual versus expected and can throw a DTC. Change the oil and the problem goes away. How about using synthetic oil? Nope. It is the anti-foam additive package that gets depleted, not the breakdown of the base stock.
http://www.hendonpub.com/resources/article_archive/results/details?id=4469
polskifacet
FWIW my recent test came out at 205 PSI on each cylinder with like 6-8 strokes.
