Quote from: AJP turbo on January 29, 2018, 09:47:13 AM
Hey just curious. Why are you so adamant about having a "dyno" tune for ATP turbos....I think you can have a really good tune without that. In fact with all the logging you do I think you get a better tune doing it remotely because you get much more data analysis for the money...I"ve said this before but on a dyno a lot of your time and money are sucked up flashing tunes and making runs...When you do it remotely the customer does a lot of the work which means more time from the tuner can be spent looking at data.
Doing Cams I think is where dyno tuning is beneficial because you can see results that you can't always feel.
If I met you at a dyno shop I would have so much more time invested in it and also being able to find the time that we are both free and a time the dyno shop is available would be near impossible.
Honestly it is because without knowing how much power I am putting down I have no idea if the tune is safe. We have plenty of data points for the stockers to get an idea on how much power you are developing at a given psi/spark combination.
With the ATPs we are only guessing by a large margin. I really don't want to blow the motor/trans/PTU/RDU by guessing at how much power I am developing based on logs. I can accept a blown component when due diligence has been done to make sure I am not pushing power past what they can handle. At that point it's one of those things was gonna happen regardless...I would be really unhappy if I blew something because I didn't do the leg work to make sure I wasn't pushing the components past what they can handle and blew something out of ignorance.
Every car is a bit different, mine tends to be more so with the SCT platform.
Its risk reward right? Do I take the risk in saving money by not dyno tuning that major of a change with the reward being I need to drop more cash on a blown motor or trans? Or do I play it safe?
You can disagree and I expect you too... I believe you are tuning Irondoors ATPs, has he dyno'd his setup to know much power he is developing?
12.5 psi on the stockers is much less air than 12.5 psi on the ATPs I would gather...
