Quote from: AJP turbo on January 27, 2018, 03:10:07 PM
I wouldn't normally guess the ecu connections or ecu but you do live in the Pacific Northwest so maybe the rainy and humid air got some things corroded? I think a remember a member here that had a horribly corroded set of ecu connectors
at this point im hosed. if the reset and fuse scraping do not work im down to tracing wires which i have no experience with.. and i am done spending money
i took apart the boost solenoid and the line that leads to the turbos holds pressue, the lines to the hot pipe and intake are clear. so it i not a issue with the pressure leaking.
that leaves the wire harness. im not going there. nope.. i will make it worse and be unable to sell the car.
so its pretty much down to this test drive. i have the 14 psi tune in place. if it still freaks out i will go back to stock and sell it off at the year when i am above water on it.
seriously bummed.
