Started by polskifacet, December 12, 2017, 06:22:07 PM
Quote from: ZSHO on December 12, 2017, 06:55:51 PMThe high idle @ cold temps is quite normal IMO! the initial open loop is likely to be 1000-1100rpm... does take to much cold weather to do that. After the block is warm mine slows down to 600-650. Very cold weather will cause it to persist! ZCheck your Battery/terminals etc especially with the BOOMIN SYSTEM! Does the Battery Saver come on the Screen? Z
Quote from: Macgyver on December 13, 2017, 06:06:17 PMI have been having the battery saver come on. Before I could sit in the car a minute with the engine off and finish up a song while texting in the car. Now the battery system saver comes on.
Quote from: lamrith on December 13, 2017, 06:27:30 PMQuote from: Macgyver on December 13, 2017, 06:06:17 PMI have been having the battery saver come on. Before I could sit in the car a minute with the engine off and finish up a song while texting in the car. Now the battery system saver comes on.I had that start when it was still warmer outside. I posted here and was told it means battery is on last legs. I replaced the battery and no problem since. Could be you are in very early stages of battery going south? normally fine, but the cold is just enough to push it over the edge..
Quote from: Macgyver on December 14, 2017, 08:13:44 PMQuote from: lamrith on December 13, 2017, 06:27:30 PMQuote from: Macgyver on December 13, 2017, 06:06:17 PMI have been having the battery saver come on. Before I could sit in the car a minute with the engine off and finish up a song while texting in the car. Now the battery system saver comes on.I had that start when it was still warmer outside. I posted here and was told it means battery is on last legs. I replaced the battery and no problem since. Could be you are in very early stages of battery going south? normally fine, but the cold is just enough to push it over the edge..Its a Juke of 2015 with 32k miles. I would hope the battery is not bad. Does Ford Warranty that? Getting more and more Key not found and memory Seating position is not working or glitchy as well.
