Quote from: Gjkrisa on September 06, 2017, 07:35:19 PM
Quote from: Mustang5L5 on September 06, 2017, 05:34:18 PM
That's how I've typically done it. I just view the PID's through a scan app on my phone with a Bluetooth app and ELM327. Still, would be nice to pull up a screen and see it instantly, especially as we are about to head into the winter and the tire pressures drop over the next few months. Oh well
Changing gears, has anyone discovered how to enable the climate control menu on the right display screen?
Using Forscan, so far on my car I've done this
- Enable navigation
- Eliminate the double beep when you step outside car with engine running
- Change number of flashes when you half press the turn signal from 3 to 4.
How did you enable navigation?
Should all be in this thread.
https://forum.xda-developers.com/windows-mobile/general/myford-touch-navigation-activation-t3368080To sum it up here's what I did.
Use Forscan to enable Nav (literally changed 1 bit)
installed .png file on USB, and loaded it into MFT by importing it as a wallpaper and unlocking Nav
DId a master reset on the MFT
At that point, it was asking for the SD card, but wasn't seeing it. I had Sync 3.8, so I downloaded some Navigation update files for the system (listed as optional on some of the posts, but I had to do it) and installed via USB. After that, I put in the ford SD card with maps, and had navigation.
Spend a good couple hours researching this before I tried it, but if I had to do it again I could probably get it done in 30 minutes...mostly spent waiting for Sync to install the nav files and reboot.
CHanging the one bit also changed the Compass screen on the right side of dash to Navigation as well.
