Started by BlueSHO, August 16, 2017, 06:06:40 PM
Quote from: SHOdded on August 16, 2017, 06:53:57 PMSome have mentioned hockey pucks end up failing, so maybe something like this:https://www.amazon.com/Single-Extra-Universal-Rubber-Adapter/dp/B06X99ZVKZ/
Quote from: SHOdded on August 16, 2017, 07:02:05 PMTheir websitehttps://www.themotoringbusiness.com
Quote from: pmezo33 on August 16, 2017, 07:42:11 PMI tried them once. Never did it again. Pinch welds work fine for me.
Quote from: BlueSHO on August 16, 2017, 07:46:22 PMQuote from: pmezo33 on August 16, 2017, 07:42:11 PMI tried them once. Never did it again. Pinch welds work fine for me.Huh? Those are pads to use on your hydraulic jack so you can lift at the factory jacking points. (pinch welds) Sent from my SM-G950U using Tapatalk
Quote from: pmezo33 on August 16, 2017, 07:56:47 PMQuote from: BlueSHO on August 16, 2017, 07:46:22 PMQuote from: pmezo33 on August 16, 2017, 07:42:11 PMI tried them once. Never did it again. Pinch welds work fine for me.Huh? Those are pads to use on your hydraulic jack so you can lift at the factory jacking points. (pinch welds) Sent from my SM-G950U using TapatalkYeah, I bought one of those pads to try out. I didn't think it made any difference at all. Plus they started to warp after only one use, so i just ditched them. Just use the jack like i've always used it.
