Quote from: TopherSho on June 16, 2017, 10:30:39 AM
Where is everyone mounting their tanks and pumps? I crawled under mine last night and i can see space to install it if it tear half my front end off.. but the pump and cabling need space as well and i am not sure where i'd plant it all.
Yeah it seems daunting, but from youtube and threads here removing the bumper cover is not that difficult from what I can tell...
Lot of guys seem to use the windshield washer tank as their meth tank. Some share duty with WW, some retask the meth kit tank as the WW tank. Lot depends on %meth and personal preference. Over 50% I think can be harmful to paint/wipers??
I would think if planning use the WW tank as meth and not running 100% then maybe using a pair of hoses to link the two tanks together would be a way to increase overall volume on a budget. Make the Sow tank a piggyback tank as it were. Mount the Snow tank so that the bottom of it is above bottom of the stock tank. Run a line from bottom of SNOW tank to near bottom of the stock tank using a grommet in stock tank. Then run a line from top half of snow tank to top of the stock tank. Maybe even have the connection on the stock tank higher than the snow tank to help purge air. This way when you fill the main tank, the fluid will also fill over into the snow tank, increasing total capacity...
Crappy picture attached of what I tried to esplain...
