Had to get her Towed in last night.
Started by thmullan, August 14, 2016, 01:31:44 PM
thmullan
So for a second time since taking ownership of this car almost 3 weeks ago, I have had to have it returned to the dealer......last night on a flat deck.
The beauty broke down about an 90 mins from where I live.
First.....came out from shopping to find almost zero power to the car and all errors and warning lights blinking and beeping.
I disconnected the battery for a while in the hopes that a re-set would allow me to start it but no dice.  Same errors, sync shutting down, lights flashing etc.
Got a boost and it started just fine and all was good.  I ran the car for about two hours consecutively before I shut it off again.  Turned it off once for a period of about 30 minutes and it fired up just fine.  Ran it for about another hour doing errands etc by this point it was time for dinner so the kids and I stopped at a restaurant, about 90 minutes later tried to fire it up and it was pretty much dead again except this time it was trying to turn over but it just wouldn't.  It would surge, cough, sputter and choke for a while until it finally died.  Called a friend 90 minutes away with a flatdeck and we loaded it up and dropped it at the dealership where I bought it.
I love this car! But I am not sure I want it back as my confidence in it is shaken.
The first time this happened it went into limp mode, dealer re-flashed it and it had been fine since.
I may have to work out a deal on a different vehicle and save myself the headache.
2014 Tuxedo Black Metallic SHO
AirRaid CAI, SW Downpipes, Corsa exhaust.
2014 Honda CBR 1000RR
1968 Chrysler 300 TNT Convertible
jbeez
I haven't heard of anyone else having this issue. Could your battery have a bad cell or faulty charging system? What year and how many miles are on it?
2014 PP SHO Darkside Metallic
K&N Panel filter, 3bar map, AJPTurbo tune, Motorcraft SP542 @.28, MSD Coils, PPE Catted downpipes, EBP Hot pipes w/ tial BOV, Tracy Lewis catch can, 170 tstat, 93 octane pump gas
AnotherGreenFusion
This kind of stuff really sounds a lot like a battery issue. Either bad battery, corrosion or bad ground somewhere.
'15 Fusion SE 2.0 AWD
CP-E Cold Side, Hot Side, αIntake, QKspl DP & RMM | Boomba Can | Cordova TB | Synapse Gen III BOV | Levels FMIC | 160* T-Stat | Steeda STB, Sway | Flatout 5700 | SCT by Unleashed/LMS 93v11
PM me for AMSOil @ Cost
thmullan
Quote from: jbeez on August 14, 2016, 03:11:28 PM
That's my first thought and hopefully the case.
2014 with 56,000kms.
I would have liked to look into it a little further but by the time we dropped it it was 2am and I had to be up for work at 5:30.
thmullan
Quote from: AnotherGreenFusion on August 14, 2016, 03:32:04 PM
Both terminals were clean and the main ground was also clean.
I thought electrical at first but after all the chugging and burping I am thinking otherwise it a combination of problems.
wraitherx
Similar issues happened with me. Turned out to be the battery. Terminals were clean and everything except when I checked voltage it was 10.4. Jumped it and it was back up with the alternator turning in a 14.2. Let it sit overnight and it was down to 6.5. Confirmed my suspicions of the battery and a draw test turned up nothing. took it to the dealer and changed out the battery at 32k. My '11 had the same issue with a dying cell and about the same mileage it was replaced. Sounds like that where your problem lies and hopefully that's what it is.
2014 SHO PP
1999 SVT Cobra Built
thmullan
The battery is certainly a weak point on this platform and had mine replaced under warranty for an upgraded MC-BXT-75-850 which is a heavy duty battery for sure....also you can always check the voltage level on the left side of your instrument cluster via "engineering mode"with the vehicle off.  Z
thmullan
Quote from: ZSHO on August 14, 2016, 05:29:34 PM
The battery is certainly a weak point on this platform and had mine changed under warranty for an upgraded MC-BXT-75-850 which is a heavy duty battery for sure....also you can always check the voltage level on the left side of your instrument cluster via "engineering mode"with the vehicle off.  Z
Damn!  I was scrolling through all the settings last night looking for a voltage display and I don't recall seeing engineering mode  :-[ :-[
Battery most likely, just to echo everyone in this thread.  If they think the battery is fine, make sure they test it properly (digital load tester) rather than an analog tester.
wraitherx
Quote from: SHOdded on August 14, 2016, 06:46:54 PM
+1 digital load tester. Keep us updated.
Z- how do you access said "engineer mode"?
2014 SHO PP
I'm on my 3rd battery, lol.
wraitherx
Nvm, found it.
Here you go OP. How to get into engineering mode.
https://m.youtube.com/watch?v=JkoUOAFC3aM
2014 SHO PP
13+SHO--Engineering Mode  Its a fairly simple process,with the vehicle off press the push button start once and while in accessory mode hold the OK button on the left side of the steering wheel for five seconds,while holding the ok button press the push button start again which is ignition mode,at this point you will be in engineering mode and the speedometer will perform a sweep test,then just use the up/down buttons on the left side of the steering wheel to navigate you through the options,also the build date,battery voltage and more can be obtained in this mode.  Z
thmullan
Awesome. Thanks for the replies, video and instructions.
