Ecoboost Performance => General Discussion => Topic started by: werecow on August 06, 2015, 09:08:48 PM
Title: Thermostat won't come out
Post by: werecow on August 06, 2015, 09:08:48 PM
Trying to put everything back to stock to take in for a few minor issues before the CPO 12/12 warranty is up.  Livernois installed the t-stat, plugs, CAI etc so I didn't do the install.
I have gently grasped the center and tried pulling but it doesn't want to come out.  Is there a trick to removing it or a recommended method?
Thanks!
Title: Re: Thermostat won't come out
Post by: BiGMaC on August 06, 2015, 09:36:40 PM
Quote from: werecow on August 06, 2015, 09:08:48 PM
Thanks!
Mine just literally fell out when I did it... Can you see a gasket or did they use one of those adhesive squeeze tube gasket materials when they installed.  Can you see mineral build up or corrosion?
Post by: r1crusher on August 06, 2015, 09:41:03 PM
It should just be sitting in there without any kind of adhesives and such.  Just take a pair of pliers and grab the end gently (use a rag to cover the pliers if need be) and give it a good tug to remove it.  It should come free without too much fuss.
Post by: ZSHO on August 06, 2015, 10:26:14 PM
Its probably the gasket hoilding it in place combined with corossion as mentioned above,would grab a heavy duty extended magnet combined with some needle nose pliers and pull that sucker out like a tooth(gently)of course and try not to spill any antifreeze,not good for the environment.  Z
Post by: SHOdded on August 07, 2015, 12:48:24 AM
Tap it with a rubber mallet?
Post by: werecow on August 07, 2015, 12:50:29 AM
Quote from: ZSHO on August 06, 2015, 10:26:14 PM
Did this and it worked.  Thank you!  I was worried I'd break the damn thing off inside the engine LOL
Post by: ZSHO on August 07, 2015, 07:46:33 AM
Quote from: werecow on August 07, 2015, 12:50:29 AM
Great to hear it worked out well for you,depending on the year of your vehicle might want to consider doing a coolant flush and possibly getting a new gasket for the stat,just a thought,the magnetic tool is a great investment combined with the mirror,works great for detecting leaks in tight spaces,especially by the firewall area and rear valve cover,best of luck.  Z    http://www.craftsman.com/craftsman-magnetic-pick-up-tool-with-mirror/p-00947095000P (http://www.craftsman.com/craftsman-magnetic-pick-up-tool-with-mirror/p-00947095000P)
Post by: shaneirish on August 08, 2015, 12:39:48 PM
I had the same problem, I grabbed the t-stat with needle nose pliers and gave it a good tug.  the gasket is on the side you can see so it's not an issue of the gasket sticking.
