Started by 2010Limited, May 08, 2018, 07:30:21 PM
Quote from: ZSHO on May 10, 2018, 02:07:05 PMQuote from: 2010Limited on May 10, 2018, 01:58:39 PMThe bolt? How about that filter Sent from my iPhone using TapatalkWow! I guess plugged,restrictive is an understatement. Z
Quote from: 2010Limited on May 10, 2018, 02:07:41 PMQuote from: ZSHO on May 10, 2018, 02:07:05 PMQuote from: 2010Limited on May 10, 2018, 01:58:39 PMThe bolt? How about that filter Sent from my iPhone using TapatalkWow! I guess plugged,restrictive is an understatement. ZJust slightly plugged. You mentioned the bolt- what would make that bad?Sent from my iPhone using Tapatalk
Quote from: ZSHO on May 10, 2018, 02:14:07 PMQuote from: 2010Limited on May 10, 2018, 02:07:41 PMQuote from: ZSHO on May 10, 2018, 02:07:05 PMQuote from: 2010Limited on May 10, 2018, 01:58:39 PMThe bolt? How about that filter Sent from my iPhone using TapatalkWow! I guess plugged,restrictive is an understatement. ZJust slightly plugged. You mentioned the bolt- what would make that bad?Sent from my iPhone using TapatalkThe Banjo bolt starts leaking with age and corrosion for starter's. Z
Quote from: 2010Limited on May 10, 2018, 01:29:30 PMThis could have been the culpritSent from my iPhone using Tapatalk
Quote from: mrhighcaliber on May 11, 2018, 03:48:24 AMQuote from: 2010Limited on May 10, 2018, 01:29:30 PMThis could have been the culpritSent from my iPhone using TapatalkAlso:Sent from my iPhone using Tapatalk
Quote from: SHOdded on May 11, 2018, 06:21:23 AMQuick reminder to please wear gloves when doing this kind of work. No need to expose yourself to these health hazards. New fluids are generally pretty safe, used not so much.BTW, great info in this thread, will help a lot of folks in the coming years.
Quote from: mrhighcaliber on May 08, 2018, 09:44:47 PMQuote from: 2010Limited on May 08, 2018, 08:48:34 PMThank you so much!Sent from my iPhone using TapatalkHere are the parts that I used for gaskets.(front and rear turbo). Don't remember which is which. But Rock Auto carries these parts. But eBay had them for a few bucks cheaper + free shipping. I will post the reassembly procedure as well. Also get yourself some copper or nickel based antisieze for all of your nuts and bolts that contact the exhaust or anything hot or that are rusty. Including the heat shield bolts. Sent from my Nexus 6 using Tapatalk
Quote from: SHOdded on May 22, 2018, 07:47:40 AMLefthand = front, Righthand = rear w/ reference to the turbos, correct? So would need the righthand/rear gasket?
