Quote from: ecoboostsho on September 09, 2015, 02:07:21 PMDang it. Should have copyrighted it. Probably couldn't have gotten that by Ford though. Lol
Quote from: ecoboostsho on September 23, 2015, 04:55:56 AMOkay...there are some known issues with the WiFi version. Do you have any of the custom PIDs working within Torque right now? Or just the "standard" ones? (I'm assuming you have it working at some level).
Quote from: Dxlnt1 on September 23, 2015, 01:34:16 PMQuote from: ecoboostsho on September 23, 2015, 04:55:56 AMOkay...there are some known issues with the WiFi version. Do you have any of the custom PIDs working within Torque right now? Or just the "standard" ones? (I'm assuming you have it working at some level). Before I changed obd device I had most of the ones I wanted working. I even had LOR working.
Quote from: BiGMaC on September 23, 2015, 07:15:06 PMQuote from: Dxlnt1 on September 23, 2015, 01:34:16 PMQuote from: ecoboostsho on September 23, 2015, 04:55:56 AMOkay...there are some known issues with the WiFi version. Do you have any of the custom PIDs working within Torque right now? Or just the "standard" ones? (I'm assuming you have it working at some level). Before I changed obd device I had most of the ones I wanted working. I even had LOR working. There are apparently some issues with the WiFi version... One thing I noted is the need to do the "advanced install"... The issues seem to be related to sleep and not being able to connect at all... Also it can interfere with phone use unless the "advanced install" method is used.Manu had a terrible experience.
