- RotM Winner
- Elite Member
- Boosted
- Logged
I've always used sp534 plugs at .028.. Without issue but step colder plugs really should be used in your application with more boost and meth. Again I haven't had issues with said plugs but bc they are inferior I switched to sp542 plugs at .028. For whatever it's worth bc I also run meth in my 2010 non PP, I've had no issues with Royal Purple 5w-20. Mostly made the switch after seeing a video of knock occurring with tuned SHO with sp534....then same tuned SHO with sp542...knock gone!
https://youtu.be/Zqz8AdJMxTYWhat you decide to do is entirely up to you.
