July 20, 2019, 12:18:56 AM
Author Topic: 2013 SHO Surging/Weird Power Delivery  (Read 442 times)
Offline SkidHash
  • Jr. Member
  • : Kansas City, MO
  • Thank You
  • -Given: 4
  • -Received: 1
  • Ecobooster
« on: May 22, 2019, 03:46:42 PM »
Hello, hope you all are having a great day/night depending on where you live.
I have been going through the ringer with my 2013 SHO non-pp with 118k miles and I can't seem to figure out what is going on with the car. After a cold start I can take the car out and it delivers power great; light throttle is awesome and it seems like the car is actually responding throughout the entire rev range. However, once the car gets warmed up (or sometimes it does this cold, but not nearly as much) and I put like 30% throttle on the car, it jumps to like 2.3k RPMs, seems to lug/lose power until ~3k, and then kicks into gear (for a lack of a better term) and launches. When I'm heavy on the throttle the issue of weird power delivery can occur but not nearly as frequently or pronounced. I don't know if this is the car saying "Oh, build a little boost then let it out then build it again then...." until the second turbo kicks in which sends the car flying or what, but I've had many a time where I've pulled out into a road and pressed the gas and had the car go into limp mode until 3.5k or so, which is a pretty scary situation.
The most annoying part about this whole thing is: the problem is not consistently there at all times. It comes and goes.
I changed the spark plugs about 4k miles ago thinking that it would fix it, but to no avail.
Forscan shows no misfires, no underboost/overboost conditions. Did a WOT run (stopped at 5k RPM) today and saw that my a/f ratio hits 10.248 at which point my LONGFT1 is 6.25%, LONGFT2 is 7.03%, SHRTFT1 is -3.12% and SHRTFT2 is -3.12%. TCBP reads 26.4 PSI with a desired TCBP of 24.6 PSI.
Since I thought that it could be a torque converter issue, I had Forscan read the TC_SLIP actual (206) and the TC_SLIP desired (1020), but I don't know what to make of those numbers.
The hesitation/surging extremely noticeable in gears 1-2 but not really in 3-6, but I don't know if that's because gears 3-6 tend to avoid the 1.5k-2.5k trouble spot or if there is some boost-by-gear magic that goes on behind the scenes that severely limits power until 3.5-4k.
Any thoughts or help is appreciated!
2013 SHO (non-pp), no mods yet
Offline ecoboostsho
  • Forum Supporter!
  • Elite Member
  • : Minneapolis, MN
  • Thank You
  • -Given: 182
  • -Received: 239
  • Ecobooster
Re: 2013 SHO Surging/Weird Power Delivery
« Reply #1 on: May 22, 2019, 04:35:40 PM »
I don't have any great insights but is your car stock or tuned?
Sent from my Pixel 3 XL using Tapatalk
2013 White SHO w/PP, Tune with AJP in progress, 3 Bar, 160T, Plugs...Mess with the Bull and you'll get the Horn. :)
Offline SkidHash
  • Jr. Member
  • : Kansas City, MO
  • Thank You
  • -Given: 4
  • -Received: 1
  • Ecobooster
« Reply #2 on: May 22, 2019, 04:41:37 PM »
Hey ecoboostsho,
Car is 100% stock
Offline ecoboostsho
  • Forum Supporter!
  • Elite Member
  • : Minneapolis, MN
  • Thank You
  • -Given: 182
  • -Received: 239
  • Ecobooster
« Reply #3 on: May 22, 2019, 04:50:43 PM »
Hey ecoboostsho,
Car is 100% stock
Got it. What gas do you run in it? Have you ever cleaned out your intercooler? Does the car use any oil?
There are some pretty knowledgeable folks on this forum so I'm sure someone will chime in shortly.
Offline SkidHash
  • Jr. Member
  • : Kansas City, MO
  • Thank You
  • -Given: 4
  • -Received: 1
  • Ecobooster
« Reply #4 on: May 22, 2019, 04:53:47 PM »
Hey ecoboostsho,
Car is 100% stock
91 is the only gas that I can find here near my house, so I run that religiously. I had the intercooler cleaned out about 2 months ago, got maybe .5 oz or so out of it. I check the oil level in the car every 2 or 3 days and have not noticed any dips at all, so from my knowledge the car uses no oil.
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #5 on: May 22, 2019, 05:18:11 PM »
Since we are ruling out oil consumption issues, next on my list would be a) checking the wastegate solenoid hoses atop the manifold, and b) more likely the orange seal on both blowoff valves.
There may be TSBs on transmission issues that apply here as well.  Particularly the control sensors and solenoid body.  Easier to check the engine stuff first tho, so lets start there.
Offline SkidHash
  • Jr. Member
  • : Kansas City, MO
  • Thank You
  • -Given: 4
  • -Received: 1
  • Ecobooster
« Reply #6 on: May 22, 2019, 06:17:24 PM »
Checked all the hoses, none have fallen off.
I was only able to get the front BO valve off but I have attached that picture. It looks perfect to me. I was not able to get the second one off, my socket was stripping the bolt and my wrenches were too long, so I don't know what the status of that one is.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1559
  • -Received: 3440
« Reply #7 on: May 22, 2019, 06:38:57 PM »
It could be a sticky/stuck wastegate hose and would also check the Boost reference solenoid located on TOP of the intake manifold to see if its stuck or open! There is one solenoid for both wastegates..
Check your (COP) Coil on plugs especially if original.
But so many variables to consider! Z
« Last Edit: May 22, 2019, 06:43:31 PM by ZSHO »
2013 Performance Package SHO| Livernois Custom Methanol Tune|3-Bar Map|Reische-170-Stat|Full Race Tial-10psi BOV in Black|PPE-Gloss Black Hot Pipes|PPE Catted DP|Corsa Sport Cat Back Exhaust|H&R Sport-Springs|Airaid-Dry-flow-CAI|CFM Performance Billet Valve Cover Breather In Gloss Black|Llumar 20%Ceramic window Tint|MSD Ignition Coils in Black|Extreme Roof Spoiler|Redline Fluids all around|Gearhead Intercooler|First-SHO With Direct Port Alky-VP-M1-100%-Methanol Injection|LMS-Custom-Dyno-Tuned @ 415whp-465wtq| Best Trap Speed of 115.54 mph|
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #8 on: May 22, 2019, 09:18:48 PM »
https://www.ecoboostperformanceforum.com/index.php/topic,3836.0.html
I would check the fuel pump control module to see if it has ever been replaced
https://www.ecoboostperformanceforum.com/index.php/topic,6600.0.html
Apparently, the EVAP purge valve is also a possibility, normally see only issues at startup, but this SSM mentions hesitation also.
https://www.ecoboostperformanceforum.com/index.php/topic,6600.msg111157.html#msg111157
« Last Edit: May 22, 2019, 09:23:02 PM by SHOdded »
Offline SkidHash
  • Jr. Member
  • : Kansas City, MO
  • Thank You
  • -Given: 4
  • -Received: 1
  • Ecobooster
« Reply #9 on: May 23, 2019, 07:26:02 AM »
Tried checking the solenoid last night and it didn't look like there were any problems, but I also don't really know what a problem would look like :D I'll go back out today once I get some smaller wrenches/sockets so I can take off the 2nd BOV and we'll see if I can find anything out of the ordinary. Thanks ZSHO!
I'm going to check the fuel pump module status, it seems like it fixes a lot of people's hesitation problems, thanks for the heads up SHOdded! I'll keep you guys posted on anything I find.
« Last Edit: May 23, 2019, 07:38:20 AM by SkidHash »
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1559
  • -Received: 3440
« Reply #10 on: May 24, 2019, 05:58:47 AM »
Check if that solenoid is restricted by using a can of compressed air or simply blow on it! sorry for the late response. Z
« Last Edit: May 24, 2019, 06:00:26 AM by ZSHO »
* Featured Topics
* Recent Topics
by MKS Tom | July 19, 2019, 11:08:07 PM
Is it possible to get into the 10s?  I mean, ANYTHING is possible...
Re: Any roofers?
by FoMoCoSHO | July 19, 2019, 07:35:39 PM
Home inspectors, jack of all trades master of none.It needs sisters......
Re: Inferred Octane
by FoMoCoSHO | July 19, 2019, 06:10:48 PM
Is OAR another way of displaying inferred octane? Or is more of an ind...
Re: Random thoughts for the day
by SHOdded | July 19, 2019, 04:06:00 PM
Big moves :)...
Re: I-G35!
by shoNoff | July 19, 2019, 01:35:44 PM
Good idea on the roof. Car looks awesome. It amazes me how up to date ...
Re: Queens addition
by Dxlnt1 | July 19, 2019, 01:01:26 PM
RIP to the goat! Pure Pontiac muscle. Another true sleeper car that on...
Re: Yet another failure
by polskifacet | July 18, 2019, 05:20:16 PM
There are 1000s of diffs because the "carrier" is the same a...
Re: rough idle no accel response and P0087 code
by Livernois Motorsports | July 18, 2019, 02:10:28 PM
That is excellent news!  Glad to hear that module did the trick.&...
Re: A sad, sad day in the history of my SHO.....
by TopherSho | July 18, 2019, 09:00:24 AM
I have a few more things to add, I have read this whole tread many tim...
Re: Random questions and shameless plug
by Black Dream | July 17, 2019, 07:48:34 PM
I haven't dug any deeper yet.  I bought new headlight bulbs ...
Re: Saw a Potential Upgraded Transmission on FB
by JagerBomb | July 17, 2019, 12:42:16 PM
Just to update, N. O. fell off facebook and had a falling out with oth...
Re: Taurus sho trans upgrade
by JagerBomb | July 17, 2019, 12:38:59 PM
Is there any company working on performance upgrades for the 6f55? Sen...
Re: "How-To" wire up a switch so you can manually turn the fans on - Kolk1
by TimmyATL | July 17, 2019, 08:55:55 AM
Yall might want look at the wiring diagram for the cooling fans. On my...
Re: AWD off message on long drive
by SHOdded | July 16, 2019, 04:52:53 PM
If the tires prove out then yes it would seem.  Or maybe the not ...
Re: Change out headlamp bulb - MKS vs SHO???
by Simonsays | July 15, 2019, 06:12:03 PM
My mks had torx screws holding it in as I have adaptive turn lights. I...
Back to top
