July 20, 2019, 12:52:05 AM
Author Topic: 2013 Focus st (250) engine noise  (Read 289 times)
Offline slim8110
  • Newbie
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
« on: May 22, 2019, 06:54:47 AM »
Hi guys n girls
I have a strange rattle when my car is up to temperature and idling, it sounds like a noise similar to dodgy tensioner, it also sounds horrible when driving in a built up area with the window down, almost like something rubbing, itís not rotor rub or anything like that as it disappears when the clutch is pushed in. So its defo engine related, Iím hoping it might be an aux guide wheel or tensioner.
Anyone had any similar or same problems?
Thanks.
Offline SM105K
  • Elite Member
  • : Arizona
  • Thank You
  • -Given: 525
  • -Received: 586
  • Land Yacht Pilot
Re: 2013 Focus st (250) engine noise
« Reply #1 on: May 22, 2019, 07:09:11 AM »
Have you checked your rear engine mount?
2013 SHO PP: AJPTurbo E30 Tune, GH Intercooler, Dicunzolo Gen2 Trans Mounts, UPR Catch Can, H&R Springs, Power Stop Brakes. Tune Only: 12.56@108.98, 391HP and 470TQ
2013 Focus ST: Ford Racing Tune, Boomba BOV, and Short Shifter.
Offline slim8110
  • Newbie
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
« Reply #2 on: May 22, 2019, 07:51:34 AM »
Thanks for the reply, Iím fairly confident itís not the engine mount causing the problem, there is no noise under acceleration, mount problems are more of a knocking sound under load, this is a small rattle you can only hear at idle engine speed.  As for the noise when driving with the windows down Iím hoping the two are linked, again I donít think the engine mount is the problem.  The noise is coming from the water pump side of the engine, Iím hoping aux tensioner or guide wheel, or something related, my biggest worry is timing chain.  Itís booked in with ford, but not for another week and 2 days.
Offline SM105K
  • Elite Member
  • : Arizona
  • Thank You
  • -Given: 525
  • -Received: 586
  • Land Yacht Pilot
« Reply #3 on: May 22, 2019, 09:18:18 AM »
How many miles are on your ST?  I have one too that just clicked 91K.  It is has the Ford Performance Calibration/Tune on it.  I am shocked at how loud the HPFP is compared to my SHO's.  It is a loud bastard.
You mentioned the sound goes away when you push in the clutch.  I would assume that could be clutch related.  Maybe a throw out bearing, possibly a broke clutch disc spring. If it was timing related I assume it would be constant or change frequency with RPM.
Offline slim8110
  • Newbie
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
« Reply #4 on: May 23, 2019, 01:20:12 AM »
It has just turned 53k, mine is completely standard with regards the engine, only mod is a front splitter and thatís it.  I canít rule the clutch out, but again my gut is telling me itís something else, again when the car engine is idling the rattle is more pronounced but the noise I mentioned when driving along is still there but not quite as pronounced, the rattle is louder if that makes sense, an when your driving along the rattle disappears and the horrible rubbing noise appears.
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #5 on: May 23, 2019, 04:19:11 AM »
Rattle on an ecoboost is to be taken seriously.  Could just be a belt tensioner, but could be timing components as well.
What oil and oil filter are you running?  Owned car since new?
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #6 on: May 23, 2019, 04:23:27 AM »
You can check f150 ecoboost videos on youtube regarding rattle.  No shortage there.
Offline slim8110
  • Newbie
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
« Reply #7 on: May 23, 2019, 04:34:49 AM »
Yes owned from new, the car has full ford service history, all oils and filters were supplied by ford, so there should not be any problems with low grade aftermarket parts.
The car is still under extended warranty I purchased after the manufacturer warranty ran out, but itís like trying to get blood out of a stone with ford UK.
It recently had a radiator fitted because of a leak, along with a few hoses and it took ages for them to agree to fix it under warranty, I had to pay the garage, and fight to get money back after, which I did, that was only back in March, Iím worried now they will use excuse after excuse until the warranty runs out in August. Thatís why I would like to know what Iím up against incase I do end up having to fix it myself.
I will check out the videos, I assume the f150 uses the same engine??
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #8 on: May 23, 2019, 07:24:05 AM »
The F150 uses the 3.5 EB engine in earlier MYs.  So not the same engine, but the same engine family.
Offline slim8110
  • Newbie
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
« Reply #9 on: May 23, 2019, 07:32:13 AM »
Lucky Americans!! You get all the fun toys!
I had a look earlier on YouTube, and I can see that the 2.0 ecoboost engine I have is basically a mixed bag, they all seem to have a noise issue related to something non critical, some worse than others! However, I would still like to know where the noise is coming from, and if it is a non critical issue, I would still like to try and eliminate it if possible, it sounds awful to the point of embarrassing when your driving along and sitting in traffic.
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #10 on: May 23, 2019, 07:35:43 AM »
If you can post a video of the sound during cold start and idle, and warm start and idle, that will help narrow the field (I hope).
Offline slim8110
  • Newbie
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
« Reply #11 on: May 23, 2019, 07:47:16 AM »
Yeah I will post one as soon as possible, what I can tell you is the rattle noise is definitely on the drivers side, (passenger side in the US) and also the noise when driving along is louder in the drivers seat with the window down than the passenger side with the window down! (Reverse that for the US)
All pointing to a problem with something connected to the aux belt.  I know I could just pop the aux belts off and if the noise is gone I will know where to start looking, but Iím afraid I will damage something and invalidate the warranty!
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #12 on: May 23, 2019, 10:05:43 AM »
Warranty issues can be a boondoggle no matter where in the world you are, but especially overseas.  Then again, you can find dealers that are really good to their customers.  Have a rat chew through the belt for ya, then your hands are clean, sort of :D
Offline slim8110
  • Newbie
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
« Reply #13 on: May 23, 2019, 11:55:20 PM »
Iíve thought about it believe me!!!lol
But I will wait until itís looked at and see what the technician discovers and if ford will fix anything that needs fixed under warranty.
If they say itís all normal and wonít do anything Iím just going to sell the car, itís still worth quite a lot of money, and I have lots of options to have a car with the same power, and no stupid noises that frankly make the engine sound like itís about to blow up.
* Featured Topics
* Recent Topics
by MKS Tom | July 19, 2019, 11:08:07 PM
Is it possible to get into the 10s?  I mean, ANYTHING is possible...
Re: Any roofers?
by FoMoCoSHO | July 19, 2019, 07:35:39 PM
Home inspectors, jack of all trades master of none.It needs sisters......
Re: Inferred Octane
by FoMoCoSHO | July 19, 2019, 06:10:48 PM
Is OAR another way of displaying inferred octane? Or is more of an ind...
Re: Random thoughts for the day
by SHOdded | July 19, 2019, 04:06:00 PM
Big moves :)...
Re: I-G35!
by shoNoff | July 19, 2019, 01:35:44 PM
Good idea on the roof. Car looks awesome. It amazes me how up to date ...
Re: Queens addition
by Dxlnt1 | July 19, 2019, 01:01:26 PM
RIP to the goat! Pure Pontiac muscle. Another true sleeper car that on...
Re: Yet another failure
by polskifacet | July 18, 2019, 05:20:16 PM
There are 1000s of diffs because the "carrier" is the same a...
Re: rough idle no accel response and P0087 code
by Livernois Motorsports | July 18, 2019, 02:10:28 PM
That is excellent news!  Glad to hear that module did the trick.&...
Re: A sad, sad day in the history of my SHO.....
by TopherSho | July 18, 2019, 09:00:24 AM
I have a few more things to add, I have read this whole tread many tim...
Re: Random questions and shameless plug
by Black Dream | July 17, 2019, 07:48:34 PM
I haven't dug any deeper yet.  I bought new headlight bulbs ...
Re: Saw a Potential Upgraded Transmission on FB
by JagerBomb | July 17, 2019, 12:42:16 PM
Just to update, N. O. fell off facebook and had a falling out with oth...
Re: Taurus sho trans upgrade
by JagerBomb | July 17, 2019, 12:38:59 PM
Is there any company working on performance upgrades for the 6f55? Sen...
Re: "How-To" wire up a switch so you can manually turn the fans on - Kolk1
by TimmyATL | July 17, 2019, 08:55:55 AM
Yall might want look at the wiring diagram for the cooling fans. On my...
Re: ďAWD offĒ message on long drive
by SHOdded | July 16, 2019, 04:52:53 PM
If the tires prove out then yes it would seem.  Or maybe the not ...
Re: Change out headlamp bulb - MKS vs SHO???
by Simonsays | July 15, 2019, 06:12:03 PM
My mks had torx screws holding it in as I have adaptive turn lights. I...
Back to top
