- RotM Winner
- Elite Member
- Boosted
- Logged
Update: Next few days I should have my car well along the way. New 2.5" stainless xpipe came in which will finally get my 3rd cat out of the equation and 4"quad tips are back from powder coat and ready for install Thursday. Still on schedule for GH turbos and new oil/coolant lines installed for Friday into Saturday. Between now and Thursday, need to install my GH intercooler, sp542 plugs, oil change and swap out my used Alky pump with my new pump. I also picked up another small tank to redo the small tank that has my windshield washer fluid in it....been wanting to do a better job on that. Picked up a sheet of 1/4 abs plastic. It's expensive here, I wanted 3\8 but a sheet was 291? No thanks. Picked up 1/4 and will make my splitter out of that to add to my front chin spoiler. Got some FTR splitter rods coming. I won't tackle that until my rear reinforcement bar finally shows up. Tasca forgot to send it with my order. I bought some hubcentric 1" spacers and will have to modify the rear inner wheel well liner mounting locations so my rear tires don't rub. I had the 1" spacers before briefly and it rubbed there over bumps, but I really liked the look and I'll have the rear bumper off anyway replacing the reinforcement bar so no better time than to modify it eliminate rubbing. Got my billet badge in and it looks great. Can't wait for it to be done.
Still waiting on my hot pipes so I'll install them along with my dual meth nozzle upgrade at the same time and add my Derale trans cooler, do a drain and fill with the transmission fluid. Waiting on another pale of VP M1 too so I won't be spraying any meth until that comes in which should be here this week.
I'm sort of mad I'm so busy with work bc I don't have the time I want to spend with my SHO but ...it will be done eventually.
