- RotM Winner
- Elite Member
- Boosted
- Logged
Yeah you're lucky you didn't have to replace the lines but you really shouldn't have needed to, with it being a 16 and low mileage...I think if you would have needed to it would have been surprising. I'm at 72k and yeah I haven't really driven it in the snow much past the 1st year of ownership but the previous owner did for sure. Even if I didn't need to replace mine I would want to...they have surface rust on them and a bit unsightly...up against New turbos..heck no! Chris from GH said yeah replace them and they will be good for an easy 70k more. I'm replacing my meth pump and I haven't had any issues yet so knock on wood with the new pump and turbos.
