- RotM Winner
- Elite Member
- Boosted
- Logged
If you guys already had the extreme dimension front chin spoiler I could send you one right now! It's going to be harder to make one for the stock lower cladding plastic as its not flat across the bottom. I know I could make a splitter for it, just haven't tried to yet. I should start looking into it.
Ok I'll swing thru...Missouri is just over yonder, be there by 3pm!
