May 27, 2020, 01:53:53 am
Author Topic: I think I may need a new rack or motor.  (Read 1836 times)
Offline Embalmer
  • Jr. Member
  • Amboy, Illinois
  • Thank You
  • -Given: 0
  • -Received: 1
  • Ecobooster
« on: April 17, 2019, 12:28:04 pm »
I'm experiencing symptoms that I believe are signs of a bad rack or steering motor.  Recently my wheel has been feeling a bit stiff, and today it felt like it was struggling to provide assist as I was steering, kind of like how being down on fluid feels on a hydraulic rack.  Has anyone had these symptoms, and just replaced the motor?  If you had to replace the rack, is it possible without dropping the engine cradle?  Thanks for any suggestions.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1932
  • -Received: 4056
Re: I think I may need a new rack or motor.
« Reply #1 on: April 17, 2019, 01:15:38 pm »
How many miles on your SHO! Did you check for Codes!
The Rack and Motor is a one piece unit (assembly) and think you need to drop the Rack in order to gain access to the Motor IIRC!
 Here are a couple links to give you some insight.  Z
https://www.ecoboostperformanceforum.com/index.php/topic,9659.0.html
https://www.ecoboostperformanceforum.com/index.php/topic,5805.msg91590.html#msg91590
https://www.hendonpub.com/police_fleet_manager/articles/2012/1112/ford_nextgen_police_interceptor_tech_training_part
« Last Edit: April 17, 2019, 02:26:13 pm by ZSHO »
Offline Embalmer
  • Jr. Member
  • Amboy, Illinois
  • Thank You
  • -Given: 0
  • -Received: 1
  • Ecobooster
« Reply #2 on: April 17, 2019, 03:24:27 pm »
https://www.hendonpub.com/police_fleet_manager/articles/2012/1112/ford_nextgen_police_interceptor_tech_training_part\
I have not checked for codes, can I use a regular scantool/SCT Xcal?
Mine is a 2013 SHO with 120k.
Thanks for the links.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1932
  • -Received: 4056
« Reply #3 on: April 17, 2019, 03:36:08 pm »
Yes indeed! Z
Offline ClearwaterSHO
  • Full Member
  • Clearwater, FL
  • Thank You
  • -Given: 88
  • -Received: 86
  • Ecobooster
« Reply #4 on: April 17, 2019, 04:52:35 pm »
 I'm sorry to hear this. I've been seeing more and more of these racks going out on FB and here now too. I wonder if they will end up recalling them. I believe the ones I've seen have been 2013 SHO's too. It's a pricey repair. Almost 3k if I recall my bill out the door. It does have 3 year unlimited mile warranty though.
2013 NON-PP SHO Tuxedo Black
Unleashed 3 Bar Tune -12.865 @ 106.5
AJP POWERED Tune - 12.59 @ 108.?
Mods: GH Intercooler, E30 Tune by AJPTurbo, SW Catless DP's, H&R Springs, MSD Coils (Is this a mod?)
Offline Embalmer
  • Jr. Member
  • Amboy, Illinois
  • Thank You
  • -Given: 0
  • -Received: 1
  • Ecobooster
« Reply #5 on: May 10, 2019, 10:43:34 am »
My weekend project...
Offline glock-coma
  • Forum Supporter!
  • Elite Member
  • Parma,Ohio
  • Thank You
  • -Given: 649
  • -Received: 699
« Reply #6 on: May 10, 2019, 04:53:53 pm »
For that job you might need more than 4 strawberry daiquiri’s.
Offline PDSHO
  • Full Member
  • Nebraska
  • Thank You
  • -Given: 65
  • -Received: 55
  • Ecobooster
« Reply #7 on: May 19, 2019, 11:04:06 pm »
Curious how this install went?
My 2013 has had a power steering fault on 3 occasions in the past 2 years, there is no warning just the fault and a service traction warning along with a total loss of power steering.
If I shut the car off and wait a minute, it is fine and back to normal.
I guess this means I am on borrowed time with my rack!
My car has 157k on it.
Thanks Greg
2013 Taurus Police Interceptor. AWD, Eco-Boost.
2015 Lincoln Navigator L, 4x4, Eco-Boost.
1995 Trans Am LT1, 6spd, Low miles, all stock.
Offline Embalmer
  • Jr. Member
  • Amboy, Illinois
  • Thank You
  • -Given: 0
  • -Received: 1
  • Ecobooster
« Reply #8 on: June 04, 2019, 11:51:28 am »
The project is finished.  Since I have AWD, in order to drop the rear subframe to get access to the rack, I had to not only drop the entire exhaust, but I had to drop the driveshaft.  Otherwise, the rack cannot be removed, short of dropping the entire subframe.
Steering is much better, but it isn't like it was originally.  It feels artificially hard to turn, and I'm wondering if the module needs a reflash.  I recently had an alignment, and it's well within specs, but my steering wheel is not centered when the car is going straight.  It's about 12:30, instead of noon, and I wonder if that has anything to to with the artificially hard effort of the wheel.
If anyone has any questions as to the procedure, I'll happily answer them.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 12953
  • -Received: 4203
« Reply #9 on: June 04, 2019, 12:23:23 pm »
I think we discussed this in another thread, but you are on the right track re: recalibration  IIRC.
Online FoMoCoSHO
  • Super Moderator
  • Elite Member
  • South West Ohio
  • Thank You
  • -Given: 695
  • -Received: 1150
« Reply #10 on: July 07, 2019, 09:58:20 pm »
I just had this done on the MKS and it did require a module flash which also triggered an ECM strategy change.
2018 Cmax Titanium Hybrid (Prius Slayer)
Needs Ecoboost
22PLE Glass Coating
2011 Lincoln MKS Ecoboost Package (Play)
AJPTurbo FFV Calibration
15 PSI, 27 Degrees, Full Rail
Full GEN V Brake Upgrade
EBC Slotted w/RED Pads
MRT Axle Back
Gone but not forgotten...
2013 Tuxedo Black non-PP SHO
2015 Bronze Fire PP SHO
* Featured Topics
* Recent Topics
by bpd1151 | Today at 01:21:26 am
I'm hoping that that opening line is laden with sarcasm.Actually ...
Re: Updated Gallery Capabilities
by bpd1151 | Today at 01:10:42 am
I have some time off from work coming up soon. I'll have to check...
by 10sleeper | Today at 12:43:07 am
Re: For those looking for something different for a 2nd (or 3rd) car
by FoMoCoSHO | May 26, 2020, 11:23:21 pm
There is another CON if you are a DIY type...The packaging is slick bu...
Re: 802SHO 2010 Build
by FoMoCoSHO | May 26, 2020, 11:08:36 pm
Pretty sweet upgrade for us Gen IV saps even without the porting.The e...
by Gjkrisa | May 26, 2020, 09:28:19 pm
I almost bought a dodge/jeep/Chrysler product once....nah I didn'...
by GhostlyGrenade | May 26, 2020, 07:35:35 pm
They must be giving SCT devices away. There's no way people are s...
Re: MRT blues
by StinkinLinkin13 | May 26, 2020, 04:32:36 pm
We'll my four muffler setup is a winner for me. Its not pretty ri...
Ecoboosted Gallery!!
by StealBlueSho | May 26, 2020, 11:27:31 am
by 802SHO | May 26, 2020, 05:15:44 am
Re: EBPF Under New Ownership!
Re: EPP CAI
Re: Let’s talk weight reduction?!
Re: Ford Recalls
Re: Brake Cooling Kit
Back to top
