So I didn't catch my water pump failure early enough and after replacing it the engine only lasted about 600miles. It's knocking horribly. It's a 2010 sho with 150K.
I found a 2013 sho engine with 100k 5 hours away with turbos for 1400$ With oil cooler (mine doesn't have that) have to research what else would be needed to swap a 13 into a 10
I found 1 decently priced 2010-2012 sho engine within reasonable distance so I can swap my new chain setup and water pump and slightly used turbos into that.
Or do I just remove the engine open it up and order some new parts from Livernois and drag it out 6 months. It's a spare car so it's not needed tomorrow, but I generally work 6days a week. I am mechanically inclined and did the turbo/timing swap myself. Have no problem pulling the engine and opening it up.
What would you guys do?
