September 18, 2019, 12:46:57 PM
Author Topic: Sunroof wonít close  (Read 441 times)
Offline shoNoff
  • Elite Member
  • : NH
  • Thank You
  • -Given: 198
  • -Received: 589
  • Shomu the killer whale
Sunroof wonít close
« on: March 16, 2019, 02:13:03 PM »
So my itís a nice March day and I decide to open my sunroof. Well I notice when I opened it that it didnít quite slide all the way back. So as I get home I hit the close button. It goes past close to tilted open. I hit the close button again it slides back. I hit the tilt button and it sort tilts up and down but wonít close. It seems to me like the motor needs to be initialized. Except Iíve never disconnected the battery. Anyways does anyone know this procedure? Iíve found one for an explorer but it did nothing. Do I have to return this to the dealer to be done in scantool?
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1645
  • -Received: 3575
Re: Sunroof wonít close
« Reply #1 on: March 16, 2019, 02:49:04 PM »
I would try removing the Battery Ground (negative) cable for 30 minutes.
I would also try to rule out a faulty Sunroof Switch Connector!
MOTORCRAFT WPT1164
https://www.rockauto.com/en/moreinfo.php?pk=3422664&cc=1503823&jsn=10707
If not there is a Initialization procedure (courtesy) of SHOdded. Z   :)
Roof Opening Panel Motor Initialization
NOTE: A new roof opening panel motor will only vent and must be initialized.
NOTE: The roof opening panel motor must be initialized when repairs are carried out on any part of the roof opening panel system, including: whenever the roof opening panel motor has been removed from the roof opening panel system, the roof opening panel glass has been removed from the roof opening panel system, the roof opening panel assembly has been removed from the vehicle, a new roof opening panel motor has been installed, a new roof opening panel glass has been installed or a new roof opening panel assembly has been installed.
Turn the ignition to the RUN position. For an existing roof opening panel motor, skip to Step 3.
For a new roof opening panel motor, push and hold the tilt switch for 2 seconds after the roof opening panel glass moves to the full VENT position and the motor stalls.
For an existing roof opening panel motor, push and hold the tilt switch until the roof opening panel glass moves to full VENT. Then push and hold the tilt switch until the following actions occur:
The roof opening panel glass motor stalls into a hard stop after approximately 3 seconds.
Then, after motor stalls, continue holding for an additional 5 seconds.
Release the tilt switch and verify successful initialization by carrying out one-touch open, one-touch close and one-touch vent operations.
« Last Edit: March 16, 2019, 03:06:22 PM by ZSHO »
Offline shoNoff
  • Elite Member
  • : NH
  • Thank You
  • -Given: 198
  • -Received: 589
« Reply #2 on: March 16, 2019, 03:18:05 PM »
Thanks Z you are the best. Also thanks SHOdded. I tried the battery for roughly a min. I will try the procedure in a min to see if I can get that to work. If not Iíll reset battery. If that doesnít work itís off to dealerland this week. I need a door switch replaced anyways may as well kill 2 birds. Iíd nornally do it myself but Iím down a right hand. Just had surgery on my hand and elbow last week.
Offline shoNoff
  • Elite Member
  • : NH
  • Thank You
  • -Given: 198
  • -Received: 589
« Reply #3 on: March 16, 2019, 03:30:51 PM »
The procedure worked perfectly. Thanks Z you are the man
Offline 802SHO
  • Elite Member
  • : Essex Junction Vermont
  • Thank You
  • -Given: 1526
  • -Received: 727
  • Boosted
« Reply #4 on: March 16, 2019, 04:44:11 PM »
Sorry to hear about your hand and elbow.  Wishing you a speedy recovery my friend.
2010 SHO non PP, GH upgraded turbos, GH upgraded IC, EPP Hot Pipes, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous 35 shot, Dicunzolo Gen2 torque mounts, SP542 .028, 160 T, Airaid Intake, 3bar, Thunderstorm Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge, Tuned by AJP Turbo
Highest Trap Speed 120.97 mph
463awhp 569 awtq mustang dyno 6/13/19
11.899 @ 119.15 New England Dragway 8/2/19 Full weight
11.690 @ 120.97 NED 8/30/19 Full Weight + Zex 35 Shot
Offline shoNoff
  • Elite Member
  • : NH
  • Thank You
  • -Given: 198
  • -Received: 589
« Reply #5 on: March 16, 2019, 04:57:38 PM »
Thank you buddy. I should be back to normal in a month or so. I had a nerve relocated in the elbow, some tendons fixed in the hand. And carpal tunnel surgery on the hand. Itís been a fantastic week or so being a righty lol. Iíve been quiet for a bit lots going on at home. Not sure if I told you but wifey is pregnant with kid #1 so been busy with that. Plus with the hand and elbow Iíve done basically nothing to the car. I couldnít even do my own oil changes it was so bad before I had the surgery.
Offline 802SHO
  • Elite Member
  • Thank You
  • -Given: 1526
  • -Received: 727
  • Boosted
« Reply #6 on: March 16, 2019, 07:14:20 PM »
Wow congratulations on the baby!  That's awesome man I'm so happy for you
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11702
  • -Received: 3837
« Reply #7 on: March 17, 2019, 01:51:21 AM »
You shoulda had an extra arm grafted in during surgery, you will need it as a new pappy!  Congrats on the impending arrival, and X1000000 on the speedy recovery!
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1645
  • -Received: 3575
« Reply #8 on: March 17, 2019, 03:41:54 AM »
Hoping for a speedy recovery and best of luck with the newborn.  Z   :)
« Last Edit: March 17, 2019, 04:17:34 AM by ZSHO »
Offline shoNoff
  • Elite Member
  • : NH
  • Thank You
  • -Given: 198
  • -Received: 589
« Reply #9 on: March 17, 2019, 10:01:44 AM »
Thanks guys. To say my wife and I are excited would be an understatement. We arenít exactly young to be having our first. But itís worked out this way and everything happens for a reason. Sheís due end of September so this will be my last summer to play lol. Not sure what the future holds for old SHOmo. Either I keep modding and buy a daily. Or leave it as is and buy something to play. I go back and forth on it daily.
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11702
  • -Received: 3837
« Reply #10 on: March 17, 2019, 12:39:25 PM »
Change is good!  A better future lies ahead, hopefully one that includes the SHO :)
* Featured Topics
* Recent Topics
by Jordan | Today at 11:42:08 AM
Tons of steps forward!...
Re: 9/15/19 New SHO ecoboost platform world record 11.214
by lamrith | Today at 08:49:43 AM
So just found out today I'm featured in the official import face ...
by Jordan | Today at 06:18:34 AM
How to kill aerodynamics 101...
Re: PD SHO knocks off a Chevy 6.2
by Quinid | Today at 05:13:51 AM
You must run premium in that 6.2 as per factory manual as well. So tha...
Re: 2014 pp driveline in 2010 sho questions.
by ZSHO | September 17, 2019, 07:04:26 PM
I wholeheartedly agree with Manu and simply put a cap on it and be don...
Re: Splitter
by ZSHO | September 17, 2019, 11:45:19 AM
It's unfortunately more of an issue with the odd dimensions than ...
Re: Ford Explorer
by ZSHO | September 17, 2019, 11:40:53 AM
2020 Ford Explorer, Lincoln Aviator reportedly facing numerous QC issu...
Re: Dragy
by ridered74 | September 16, 2019, 08:32:35 PM
The track where I trapped 118 I have some suspicions about. LOL! Makes...
Re: Random thoughts for the day
by SHOdded | September 16, 2019, 04:29:12 PM
Save on K Source Towing Mirrors at RockAuto
by RockAuto | September 16, 2019, 10:00:45 AM
K Source, Inc. is offering RockAuto customers a 10% off instant rebate...
Re: rear shocks with performance package
by ZSHO | September 14, 2019, 01:58:11 PM
Warranty on the Monroe vs the Motorcraft Shocks.  Zhttps://www.m...
Re: 3 months free SiriusXM
by FearlessAZ | September 14, 2019, 06:36:30 AM
When I first tried this on my MKS, it said I just had a trial that end...
Re: Taurus sho trans upgrade
by Blackhawk | September 13, 2019, 07:12:41 AM
I'm sure Quaif would realize the limited number of people that wo...
Re: Rougher ride under lower RPMs and off throttle input
by avidmotion | September 12, 2019, 09:27:34 PM
When my ptu was going it made a weird whine sound varied by rpm.......
Re: DiCunzolo GEN2 Upgraded Trans Mount Review!
by avidmotion | September 12, 2019, 09:20:09 PM
Subscribe ...
Back to top
