The Forum is being super slow and not loading on my phone or pc, so i will reply here an not with the reply-qoute buttons
We will do a compression check prior to pulling the motor. I am taking it to my old mechanic and there going to do the job 1500$ cheaper *IF* it is just a gasket. So we will do a compression check, and if it fails as expected we will go from there and pull the motor.
I had the valves cleaned prior to meth installation at around 50k miles. I saw numerous valve caking complaints so i did have them blasted once. car has 20k more miles now, about 15k with plenty of meth.
The check valve is in the last 24 inches of hose, right before the nozzel, it is a #5 devils own, about 700ml flow, nets me .80 stft readings on hard acceleration.
spark plugs looked amazing, i had to change them at 60k due to the one step colder being a issue, the ones i pulled that were the replacements were super clean front and back except for the two wet/oiled ones.
gasket questions. what gasket am i going to use? is there a better gasket than the oem replacement to go with? Rockauto had a few .. but it has been years (or 20) since i have done headwork (nova/mustang days)
