September 18, 2019, 01:34:08 PM
Author Topic: 2015 SHO PP ruff idle slow to start but power is still there  (Read 456 times)
Offline EAST TX SHO
  • Jr. Member
  • : Nacogdoches, Texas
  • Thank You
  • -Given: 6
  • -Received: 2
  • Ecobooster
« on: March 08, 2019, 05:27:17 PM »
2015 SHO with Performance Pack
82k miles
ALWAYS use 93 octane... name brand stations
Today - car turns over a few times more before firing up.
Rough idle - intermitent - ruff, lower than normal idle, idle varying... other times normal
stomp on it, and power seems normal.
Dont see any vacuum hoses loose or disconnected.
Last tank of premium was 200 miles before problems started.
HAD a check engine light... now its gone.
ideas?
I have a FORD ESP warranty to 125k miles, but I am not near my prefered dealer.
17 Explorer Sport Twin Turbo
15 SHO PP hard loaded
93 SHO
Online SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11702
  • -Received: 3837
Re: 2015 SHO PP ruff idle slow to start but power is still there
« Reply #1 on: March 08, 2019, 05:36:41 PM »
When did you change the battery last?  What are the CCAs on it at the present time?  Might still be a code in the PCM, check that.  Do you leave an OBD adapter plugged in?
After all that could be an EVAP purge valve lol.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1646
  • -Received: 3576
« Reply #2 on: March 08, 2019, 05:44:41 PM »
X2- Battery original! Did you notice the Battery saver pop up on Sync screen!
Check for corrosion on battery terminals. Z
« Last Edit: March 08, 2019, 05:46:38 PM by ZSHO »
Offline EAST TX SHO
  • Jr. Member
  • Thank You
  • -Given: 6
  • -Received: 2
  • Ecobooster
« Reply #3 on: March 08, 2019, 06:03:59 PM »
New battery 10 months ago.
Turns over strong. just takes a few extra revolutions to start.
PLUS once its running, battery isnt in use... so how does battery affect ruff idle.
(THANKS for reaching out)
93 SHO
Offline TopherSho
  • Elite Member
  • : Eugene Oregon
  • Thank You
  • -Given: 477
  • -Received: 302
  • 1st boosted rig!
« Reply #4 on: March 08, 2019, 08:24:06 PM »
82k miles
ideas?
If there are no codes,  i will go with a leaky injector;  and or bad plug/cop ... or more likely unmetered air that is low enough volume to not matter under load.
get a data log of the rough idle ..  im not sure what to look for with unmetered air,  but a spiking stft from leaking injectors would be noticeable.  any chance you ran injector cleaner or had the dealer clean the fuel system?
Last thought .. also pull a plug and have someone scope the back of your vavles .. gunked valves will cause air mix issues and lead to bad ignition
2010 non-pp, 50k miles, 3-bar,  .30 plugs, 170-T-stat, SNOW-KIT STG1, AJP TURBO METH TUNE-REV3
Best of 12.61 no DA correction
Online SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11702
  • -Received: 3837
« Reply #5 on: March 08, 2019, 10:42:41 PM »
At idle is when the generator is making the least amps.  Depending on the items consuming power at the time, such as with remote start with auto climate control and dashcam and phone charger and audio system and headlamps etc, the battery might have to provide supplemental power to keep everything running.
I would check the code, if it is P045x, it is very likely the purge valve.  Did you first see it happening after a fuelup by any chance?
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1646
  • -Received: 3576
« Reply #6 on: March 09, 2019, 04:34:59 AM »
I think SHOdded is correct that the Purge Valve is a likely culprit as the Valve could be stuck open and sometimes fail sooner than later.  Z
Here's my very own Dedicated thread below.
https://www.ecoboostperformanceforum.com/index.php/topic,7133.0.html
« Last Edit: March 09, 2019, 05:53:14 AM by ZSHO »
Offline EAST TX SHO
  • Jr. Member
  • Thank You
  • -Given: 6
  • -Received: 2
  • Ecobooster
« Reply #7 on: March 09, 2019, 09:12:02 AM »
Check engine light went out - everything back to normal.
Can I still get a code reading if the light is out - is it stored?
I had about 200 miles on the most recent tank of gas... less than 1/2 full when it started stumbing.
93 SHO
Online SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11702
  • -Received: 3837
« Reply #8 on: March 09, 2019, 09:55:50 AM »
CELs are only for major issues.  the remaining codes are in the PCM and do not trigger a CEL.  You HAVE to check the PCM for codes, one way or the other.
* Featured Topics
* Recent Topics
Re: Welcome to the 11 Second Club!
by Macgyver | Today at 01:17:27 PM
Thanks for the link Z!  My new personal best time and trap speed ...
by ZSHO | Today at 01:13:40 PM
Progress of any kind is always welcomed!  :)  That especiall...
Re: 9/15/19 New SHO ecoboost platform world record 11.214
by Macgyver | Today at 01:09:39 PM
So just found out today I'm featured in the official import face ...
by Jordan | Today at 06:18:34 AM
How to kill aerodynamics 101...
Re: PD SHO knocks off a Chevy 6.2
by Quinid | Today at 05:13:51 AM
You must run premium in that 6.2 as per factory manual as well. So tha...
Re: 2014 pp driveline in 2010 sho questions.
by ZSHO | September 17, 2019, 07:04:26 PM
I wholeheartedly agree with Manu and simply put a cap on it and be don...
Re: Splitter
by ZSHO | September 17, 2019, 11:45:19 AM
It's unfortunately more of an issue with the odd dimensions than ...
Re: Ford Explorer
by ZSHO | September 17, 2019, 11:40:53 AM
2020 Ford Explorer, Lincoln Aviator reportedly facing numerous QC issu...
Re: Dragy
by ridered74 | September 16, 2019, 08:32:35 PM
The track where I trapped 118 I have some suspicions about. LOL! Makes...
Re: Random thoughts for the day
by SHOdded | September 16, 2019, 04:29:12 PM
Save on K Source Towing Mirrors at RockAuto
by RockAuto | September 16, 2019, 10:00:45 AM
K Source, Inc. is offering RockAuto customers a 10% off instant rebate...
Re: rear shocks with performance package
by ZSHO | September 14, 2019, 01:58:11 PM
Warranty on the Monroe vs the Motorcraft Shocks.  Zhttps://www.m...
Re: 3 months free SiriusXM
by FearlessAZ | September 14, 2019, 06:36:30 AM
When I first tried this on my MKS, it said I just had a trial that end...
Re: Taurus sho trans upgrade
by Blackhawk | September 13, 2019, 07:12:41 AM
I'm sure Quaif would realize the limited number of people that wo...
Re: Rougher ride under lower RPMs and off throttle input
by avidmotion | September 12, 2019, 09:27:34 PM
When my ptu was going it made a weird whine sound varied by rpm.......
Back to top
