Fuel line for Ethanol Analyzer
Started by StealBlueSho, March 07, 2019, 12:30:59 PM
StealBlueSho
So if you are going to throw an ethanol analyzer on your stock or LMS HPFP you are going to need a new low side fuel line from the HPFP to the connection at the firewall.
I wasn't gonna go cheap with a nylon tube with plastic quick disconnects so I had a shop fab one up for me...
The problem is the stock fuel line is a female at the HPFP and a male at the firewall. The ethanol sensor has to male connections so I needed a female quick disconnect at the firewall as opposed to a male quick disconnect post.
Here is the parts list and pictures.
Must say not a bad number for guesstimating off knock readings and fuel trims.
StinkinLinkin13
Can you give us a list on what your using and where you got it? Prices? I've been looking to add something like this. Haven't really got a clue on what is all involved in making it happen including sensor, apps etc....  Thanks.
Livernois Catless downpipes with Totalflow mufflers - AJP E40/Meth tune - Firestorm HPFP - DW 300 LPFP - Kenne Bell Boost-a-Pump - 3 Bar Map - Alky Controls Meth Injection - 160° Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
StealBlueSho
Quote from: StinkinLinkin13 on March 07, 2019, 12:36:16 PM
So the parts list is in the post for the hose that was built. For the rest of it...
https://www.fuel-it.com/bluetooth-flex-fuel-analyzer/
For the Flex-Fuel sensor I went with Part# 13577429 which is $50 on their website, you can get it for $25-$35 other places.
You do NOT need the adpater for GM Sensor part# 12570260
All in, it was about $300 for the bluetooth portion which is $200, the sensor is $25, and the fuel line was $80 plus they went ahead and installed the sensor along with the line. I connected the bluetooth portion which is just a ground and positive connection.
StinkinLinkin13
Awesome man...  Which is the flex fuel sensor? Is the Continental part is the Bluetooth piece? Just a little confused be the pics. Seems like only one sensor.
StealBlueSho
Quote from: StinkinLinkin13 on March 07, 2019, 04:26:24 PM
The Continental part is the actual analyzer. The Fuel-it part connects to the continental part to send the information via Bluetooth.
StinkinLinkin13
shoNoff
Badass setup SBS your build has been a joy to follow. Very well thought out man.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
