170 degree t-stat and heat
Started by boostedflex, August 22, 2013, 02:49:13 PM
boostedflex
Hey guys,
Slowly starting my mods, I did an Airaid as the dealer was cool with it, now I am thinking of a 170 t-stat, which I am sure the dealer wont notice or care about.  My question is, how does this affect the in car heat on cold days?  I noticed last winter my Flex took fffooorrreeevvveeer to get warm inside on really cold days.  I do not want to do this mod if it will make that even worse.
Anyone have any thoughts or experience on this?
2017 Explorer Sport
Stock
2012 Flex, sold
Unleashed 93 tune, 170 degree t-stat, Airaid intake, Motorcraft SP534 plugs
I am pretty sure your heater will be less efficient.
I can't comment, AZ and all. :) Winter is 60 BRRRRR
Off the top of my head, since coolant flow would start earlier, it will not be as warm as with the standard tstat.  Do you drive city or highway?  Where are you located, and how cold are we talking about?  May want to get an aux 12v heater to get you through the interior warmup period.
QwikSHO
For Michigan winters I have adequate heat with my 170 t-stat.
arttyszka
Crash, "adequate" is in, "well, that will have to do" or as in "no problem"?
Thanks
Art
2014 Explorer Sport
Lund Tuned | 170 t-stat | K&N Panel | H&R Springs | Coolbulbs.com HID's
Larrylu
Quote from: crash712us on August 22, 2013, 05:57:09 PM
Crash what's a Michigan winter like?  I'm in upstate NY. Course with global warming winters just don't seem as bad as they used to be!
Flex does have more volume to heat up than the SHO ...
jomc111
Quote from: Larrylu on August 22, 2013, 06:28:45 PM
Similar to your winter here in mi
2009 mazdaspeed 3 Garrett GT3076R//HKS SQV3 blowoff valave//Autotech internals//Pauter rods//CP pistons// ACT 6 puck clutch// Lightened Flywheel//PG tubular manifold//Corksport downpipe// Streetunit racepipe// Greddy Ti-C catback//HKS type 0 Turbo Timer// Manual boost controller// Eibach pro-kit// Koni FSD dampers// JDM yellow fog overlays// COBB short throw shifter// oil filter conversion // BSD //
Parted out - sold
2010 sho -stock -sold
2014 focus st
ecoboostsho
I have no problems with mine in Mn and it gets plenty cold up here. Then again I always use the heated seats...
arttyszka
Quote from: ecoboostsho on August 22, 2013, 08:48:42 PM
I'm in MN too, so that's good news.  I grew up in MI and a MN Winter is a lot different than what I was used to in MI . . .
2014 Explorer Sport
EcoBrick Bob
I have run a 170 Deg T-Stat for over 3 years in my Flex.  I return to Iowa at Christmas for at least a week every winter.  I have noticed NO difference in heating up the engine & heater at any time.  I also was running a 160 deg T-stat in my Denali XL for at least 6 years, and I had the same results.  It will not affect the heater time.  In both instances, I saw a 10 -15 degree drop in Coolant temp over stock T-stat.  In the summer, when over 80 deg, it helps to have the fans come on sooner, to match the cooler T-stat, especially if you are at a strip.  Otherwise, it really makes no difference from my experiences in 4 vehicles with 160-170 T-stats.   Go for it.  It is a much better investment than the AirAid...
Naples, FL & Clear Lake, IA
boostedflex
Thanks everyone, I am in lower New York, on some winter mornings I would see 5 to 10 degrees outside.  I will probably go with this then, what I had observed was the engine itself took a long time to reach temperature with both the main and rear heat on high in stop and go traffic (mostly stop).  My guess is once it hits 170 I should have enough heat :)
Now I just need to wait for warranty to expire to get the new 4+ tune, I am DYING to have a low to mid 13 second brick :)
2017 Explorer Sport
Stock
2012 Flex, sold
Never had issues with heat blowing from the vents with my 170 degree thermo.
This after having driven through two seasons worth of arctic tundra-like weather here in Chi-Town, when temps sometimes would be not only in the single digits, but also at times, below zero.
You'll be just fine. You'll benefit more by having it tuned, as well as having the cooling fans cycle on at a lower temp and/or with more frequency.
