- RotM Winner
- Elite Member
- Boosted
- Logged
Meth log went down to 70 degrees and GH IC went down to 77 degrees.
Ive been thinking about meth and the new GH IC. How can I utilize meth the same way I am now with the new IC? I'm wondering if I need the HPFP to make that happen while staying with pump 93. I want to make sure the new IC is being used to my benefit as much as possible. I don't want to dial back meth if I don't have to. Lol if I want to run things on the super safe side I would remove all my mods an thats not happening. So running the new IC to then dial back Meth sounds counter productive to me. Imagine that...85 degree ambient outside and 35 degrees at the manifold or less! Lol maybe that will cause a fueling issue but I dunno. Sounds good to me to have it below zero at the manifold while its 95 degrees out
