I found the section in my workshop manual...
"Overview
Dimmable Backlighting
Dimmable illumination provides backlighting to certain switches and control components when the parking lamps are on. The level of backlighting intensity is adjusted by instrument panel dimmer switch.
Non-Dimmable Backlighting
Non-dimmable illumination provides backlighting to the door lock, roof opening panel and window control switches when the accessory relay is energized.
The dimmable switches and components are illuminated when the parking lamps are on. The instrument panel dimmer switch controls all dimmable interior illuminated components. On vehicles equipped with autolamps, if the exterior lamps are activated during the daytime, the message center illumination remains at full intensity and does not dim from the instrument panel dimmer switch during this condition. If the vehicle travels under a bridge or a tunnel, the low level of ambient light causes the illumination level of the message center to change to the level set by the instrument panel dimmer switch. The message center illumination changes back to full intensity when the intense ambient light is restored.
When the parking lamps are on, the SCCM monitors the input from the instrument panel dimmer switch. The SCCM sends a message to the BCM over the HS-CAN relaying the instrument panel dimmer switch input. Based this message, the BCM sends a pulse-width modulated voltage to the dimmable switches.
The BCM also sends an illumination dimming level message over the network to control the backlighting intensity of networked modules. If a receiving module deems data received from the BCM invalid for 5 seconds or less, the receiving module defaults the backlighting to the last setting.
If the receiving module does not receive the illumination dimming level message from the BCM or if the data received is deemed invalid for more than 5 seconds, the receiving module sets a DTC in continuous memory and defaults the backlighting to full nighttime intensity.
When the accessory delay relay is energized, switched voltage is supplied to the window control, roof opening panel and door lock control switches.
