- RotM Winner
- Elite Member
- Boosted
- Logged
I found mine at O'Reilly Auto Parts. When I did this I had muffler deletes already and had room for the length of the tip. I would think that if you only cut the tip off the muffler, you could run into a length issue with the new tip sticking out too far which would look silly IMHO. Plus you will need a good inch of pipe left over to attach. I'm not sure how this would work when you would still have the mufflers.
I'm not saying it can't be done but the amount left over after you cut the tips off to attach the new tip...and the length you would want might make it harder to find a tip for that application.
You'll have to take some measurements and Google it and see what comes up. Another thing is perhaps you could cut the new tip down? Or have an exhaust shop weld some better tips on? Things start to get tricky here as the options grow...if youre going to end up spending money to modify..looking into an axle back (cheaper than cat back) might be another route. Dunno.
