- Jr. Member
- Econoob
- Logged
I got the orange hose removed and replaced the hose that had been tapped in to. I searched high and low in town but ended up having to order the tee fitting. Luckily it'll be here tomorrow. The last issue is that my break boost line is hard plastic from the booster to the intake except for a small section of 15/32's flex hose near the check valve. Only thing is that the first section of hard plastic line seems smaller than the longer section that connects to the intake. Do I tap in to the hard plastic? And if so do I do it in the smaller (and smaller diameter)section or the longer section that runs along the strut tower brace then to the intake?
And yes I reconnected the rear bov. It's zip tied away from the manifold.
2014 Explorer Sport. NGK plugs, 170 degree thermostat, 3 bar, MDesign intake, EPP Hot Pipes, TiAL bov, Livernois catted DPs, 3rd cat delete, Borla S-Type with Magnaflow X resonator, Unleashed 93 tune, AJPTurbo tune, H&R springs, TRS Morimoto hid and led fog kit
