Quote from: Brucelinc on March 11, 2019, 09:40:59 AM
Old thread but maybe someone who has used the new tuner can answer a couple of questions. I have one for my Mustang but haven't used it yet due to non-stop snow and the car being in hibernation. Flashing the tune will be simple enough but has anyone done any datalogging with the new device? I am familiar with SCT and Livelink but I am not sure about how to use the Livernois tuner for that.
Also, I realize to flash the tune, the car ignition is on but not running. To display the gauges, however, do I start the car and then touch "diagnostics and tools?" I am sure that when I actually use this device, it will be obvious but since there is no user manual that I know of, I thought maybe someone could share their experience with the new tuner.
I have a write up somewhere... but to answer your questions...
1: Yes, I have done data logging with the LMS device. Being as it's still in BETA it's rather painful and not informative at this point. The resolution is in the tenths of a second which is too slow, and you can only data log 6 pids at a time. The resulting information is dumped into a CSV file that you need to use excel to build the graphs. Not hard, but not as easy as SCT makes it.
2: Start the car, go into diag and tools, and then select data logging. You will see 6 spots on the screen the to load pids into. Select the spot, navigate through the available pids, and select which one you want to monitor. Be warned that a lot of the pids will come back unsupported. You will want a stylus for this as the print is very small and using your fingers to select is difficult.
3: Until this feature is polished and finished I would use your SCT device to monitor. As well as log for that matter.
I talked to Andy one of their tuners about it. They are working on building the PID list as they are customizing the PIDs and manually building them. It will take time for that... if you have questions please feel free to PM me.
