- RotM Winner
- Elite Member
- Boosted
- Logged
The day I hit the track I did the PTU, got 9 oz out of it...it needed a change, overall I was expecting the fluid to be worse, and I changed the RDU, got out 24-26 oz. Replaced all fluid with Royal Purple. So is Amsoil better than Royal Purple? I thought I was putting the best in it.
Tom, when you do the RDU, only back out the fill plug a little bit and do the rest by hand, I backed it out too much and pinned my ratchet. That was fun.
