In case you hadn't seen my other thread- my rear turbo is toast. I'm having a hell of a time getting that one out. Any tips from those that have pulled that one out?
Basically where I'm at now is the oil feed, coolant lines and 1 manifold bolt need to come out.
Does the feed line need to be disconnected at the block? I can't seem to get the torx bit in the screw from that angle.
Is it easier to remove the engine lift bracket for more space?
Thanks in advance for any tips
