Quote from: Cole.C on February 07, 2018, 10:11:22 AM
Your describing the exact series of warnings I get when my tune fails to load on my p.o.s sct itsx.. lights flash once and it dings at you and throws all same warnings. IDK of its related but maybe a dying battery caused pcm to do something weird with tune? Revert to stock and reload tune and see if issue persists before removing parts?
As we have been down this road Before,
and it cost me a ECU, a tow, An SCT lockup (back to SCT), ETC ETC.
WORDS OF WISDOM: and this ALSO comes from a Ford Master Tech:
Never load a Tune Without Having the Battery on a Dedicated Charger,
and that means having the Battery at Full Voltage. Make Sure the lights
are Off, Battery up to Snuff, and you will be Fine, Low battery Voltage, You
run the risk of the the above, (it DID) and
it can cost you a bundle...
