1985 f150 scab 5,0 efi
1978 corvette l82, restored during HS
1967 mustang coupe 289, 3 speed, bought it in boxes
1986 Chubby C20, 454, 400t
1988 Chubby k1500, tbi350, absolute dog
1997 dodge 1500, excab, 5.9
2004 chubby 2500hd, 6.0
1979 chubby k5, 406, 12:1, crane cam, windage tray, bow tie heads, windage tray, long tubes, single plane, 650 holley, 350t, 3500 converter, valve body, b&m shifter
1995 mustang gt, OEM block, eagle crank and h beams, je pistons, AFR heads, custom nitrous cam, RPM II intake, 42lb injectors, NX plate 175 shot, Astro trans, tri-ax shifter, Strange 10 ways, 3.73 gear, 275 radials
1979 F250, 10" lift, trac bars, 42" tsl's, DOVE 460, solid roller, 850hp holley, 4 speed, Yukon front locker, rear MIG locked
1997 BMW 328i, 5.0 short block from my basement that I had over-reved, gt40p heads from under my toolbox, AFM cam I had in a bucket, weiand intake I bought for $40, holley carb from an old f100, custom accessory brackets, fox PS pump, v6 mustang starter, 80's ranger radiator, spare shorty headers, 3g alternator, custom mounts, holley blue pump fed by gutted stock sending unit, MSD 6al ignition, c4 trans i bought as a core, custom throttle and trans cables, custom PS lines, custom driveshaft that I didnt make, b &m shifter, interior &exterior stock with factory gauges and everything through factory key
1989 CRX, gutted, h22a1 swapped, driveshaft shop axles, custom header and test pipe, NX single nozzle 125 shot, 1800#'s
2016 Mustang GT, premium, PP, 6 speed, Lund tune
2013 f150 limited ecoboost, CRP compressor wheels, snow stage 3 meth, Corsa exhaust, turbosmart BOV, pcv deleted, custom blow-by tank, Aem filter
