Its busted again, Same behavior. super bad stuttering under prolonged boost in 2nd and 3rd past 4000 rpm.
it was doing perfect, multiple starts and stops, hard driving then normal driving. but on the way home from Coburg Pizza, it hiccuped 1x in 2nd. that made me suspicious so i dropped the mini-me off and went out and gave it a hard push from a stop and sure enough 2nd was a mess past 5000 rpm, and keeping my foot in third made it start having a seizure after 4000 rpm in third.
No logs, will try tomorrow.
there has been no handheld hooked up since the ''fix'' of resetting the SCT. so the only thing that has changed is 'time' on the car.
if this is a bad ecu that losing cell data, i may have conniption fit. i am going to pull all the tunes off the handheld, then put the good ones back. and re-flash the car to oem, then back to the good 15 pound tune.
sigh
