anyone figure out how to rig the LED "fog lights" to run with the headlights off
Started by QwikSHO, August 12, 2013, 12:44:10 AM
QwikSHO
No and the LED's really are called something like auxiliary parking lamps.  So they really aren't or intended to be fog lamps.  I added strip LED's to the headlamps for DRL's but they are on when the engine is running.  I didn't wire them to work with the lights.
In this photo the headlights are off, the light is just a reflection of the flash....
QwikSHO
jmr061
Old news. Yes on the 13s with HID headlights the turn signals are used as DRL. On halogen models either the low beams or turn signals can be used. The led strips in the lower corner of the bumper are not used as DRL.
The dealer must activate them through special software/equipment.
Jason
Jason
16 Edge Sport
Kolk1
If enough people are interested, I can pull mine apart and figure it out. Same way I found how to add a toggle switch for the fans for the drag racers. lol. Just have a relay off the running lights toggle a new 12volt source for the LEDs. Should be simple.
QwikSHO
Quote from: Kolk1 on August 21, 2013, 12:38:15 AM
Have wiring diagram, will travel.   Either straight from the lights themselves, or from the headlight switch.
Kolk1
Id have to look into it on the SHO, but on some cars, you just hook up a jumper wire in the fuse box. Remove the fuse for the LEDs, and run a jumper from the running lights over to the Output side of the fuse you removed. If possible, its a 5 minute mod. But ill need to so some testing, and find the easiest way to do it safely.
QwikSHO
I'd definitely be interested in this.  Without wiring diagrams, I'm dead in the water.
Kolk1
Ok, I'm looking at my car, and they already turn on without the headlight with the switch set to parking lights.
So your only option is if you ONLY want LEDs, you'll need to add a new switch.
QwikSHO
That's what happens with mine too.   And adding a switch is something that I figured would be true.
Why Ford didn't give the Taurus a true fog light, I'll never know.
Kolk1
QwikSHO
Yeah, but Audi also has their LED's run during the day without the headlights on.
Kolk1
QwikSHO
wasinger3000
13' GTCS, will be missed.
