Ecoboost Performance
Troubleshooting, Maintenance, TSB Articles
Maintenance, Oil, and Fluids
2010 Flex limited EB oil
Started by mcrmb1, December 05, 2017, 08:49:41 AM
mcrmb1
Lucky
Jr. Member
Ecobooster
Well my 2010 limited EB Calls for 5W20 but I changed to 2012 timing components Actuator, Camshaft Gear, Tensioner, Timing Chain, Chain Guide, new water pump and Turbo should i go to the 5W30 oil or stay with 5W20 ?
2010 Ford Flex Limited 3.5L Eco-boost Upgraded Timing and water pump to 2012 version
Forum Supporters
SHOGAZM
Re: 2010 Flex limited EB oil
December 05, 2017, 09:04:10 AM
IIRC the primary reason FMC switched to 5w30 was simply for fuel efficiency ratings.
I can tell you that my 2010, which now at it's core, lives a 2014 production block heavily modified by Livernois Motorsports, still runs the 5w20 with no issues whatsoever.
I'm sure based on my own experiences, you'll be fine running either weight.
Forum Supporters
December 05, 2017, 10:02:51 AM
5w20, quality full synthetic. Motorcraft oil filter preferred. Others might work, or cause startup rattle, so I stick with MC.
