Gearing acting up help please
Started by AdrianSHO, November 26, 2017, 02:51:52 PM
AdrianSHO
Hey guys so last night I was driving and my car basically just stopped driving and started acting like it was in neutral no matter what gear I was in. When I came to a stop in drive it won't take off until my car revs up to 5k it almost seems like my car is half in neutral and half in drive it also does it in reverse. Any thoughts on what it might be? Anything helps thanks guys
2011 PP, intake, snow performance meth, 93 octane, 3 bar, plugs, custom tune by Torrie at unleashed
What codes do you have?  Did you ever fix that P0020 & P0052 Code ?  Z
I would suspect TSS/OSS sensors right off the bat, or possibly the TRS sensor.  I think there may be a TSB or two on it ...
https://www.ecoboostperformanceforum.com/index.php/topic,496.msg23786/topicseen.html#msg23786
AdrianSHO
So far I have no codes and yeah I fixed the solenoid and it fixed my issue before but I'll check that out and see what happens
AdrianSHO
Quote from: SHOdded on November 26, 2017, 04:21:16 PM
What's the location of that sensor
AdrianSHO
Quote from: ZSHO on November 26, 2017, 04:01:53 PM
It is throwing p1000 what would that one be?
pmezo33
Quote from: AdrianSHO on November 27, 2017, 07:45:34 PM
https://www.autocodes.com/p1000_ford.html
Is your scanner able to read transmission codes?  Make sure it does because a lot of the cheaper ones aren't able to.  Most just read generic engine codes.
Quote from: AdrianSHO on November 27, 2017, 07:31:51 PM
Should be inside the main control cover, visible when you remove the air box and ducting assembly.  The following are all accessible through this cover:  tss sensor, oss sensor, trs sensor, valve body, and solenoid body assembly.
Did you Disconnect the battery @ one point ?
AdrianSHO
Quote from: ZSHO on November 27, 2017, 09:33:04 PM
Haha it's a good point I definitely thought about it so I might as well give that a try tonight when I'm home if not I'll refer to those sensors!
Any noises? Wasn't there a tsb for the half shaft separating awhile back?
AdrianSHO
Quote from: glock-coma on November 28, 2017, 10:48:13 AM
Yeah it doesn't sound the best when I turn it on and shift through the gears you can hear it pretty good by my front driver side tire
Quote from: AdrianSHO on November 28, 2017, 03:16:10 PM
This what I was referring to
https://www.google.com/amp/www.techtimes.com/amp/articles/13133/20140816/ford-recalls-83-250-edge-taurus-flex-and-lincoln-vehicles-over-power-loss-problem.htm
