ProMeth AN stainless braided lines...
Started by ddlopes, November 09, 2017, 07:42:50 PM
ddlopes
So after the issue I had with push to connect fittings leaking on my Snow Performance meth kit I decided to switch all the lines to stainless steel braided lines with AN fittings. I went with ProMeth because I've purchased their products in the past and liked their customer service. I measured all my original lines and emailed Rodney at Prometh with all the measurements. All their line are made in-house so you can get whatever size line needed for your application. Best part is I ordered the lines and all the fittings Monday afternoon. Everything was shipped out the next day and tracking info was emailed to me. Today (3) days after I ordered everything they arrived at my door. That's awesome considering ProMeth is located in California and I'm in Massachusetts. So if anyone out there is thinking of swapping out there push connect lines I highly recommend ProMeth. I'm relieved to know I shouldn't be having anymore leaks. Which is just in time for me to go back to the dyno after Brad tweaked the tune a bit. Right now I'm at 433hp and 509trq hopefully we sneak out a little more.
2013 SHO P/P mods: EcoPower Parts dual CAI, 3 bar, PPE catted down pipe, SCT X4, 170 degree thermostat, SNOW PERFORMANCE methanol stage 3 with ProMeth staineless steel braided lines, AeroForce gauges, Hot pipes, custom boost activated cutout xpipe, tial bov, Tial Wastegate mod, GH intercooler, MSD coils, AFE throttle spacer, UPR catch can, Rovos Durban wheels, AJP tuned to 389hp and 503trq on mustang dyno
Just about at the limit of a stock motor.  Good luck with the ProMeth setup.  Hopefully the last major change you will have to make.
J-Will
Good info. They ever get a controller? It also looks like they removed the Ecoboost direct port kit.
3-bar
SP-542 plugs w/ GH gap
BoostfoSHO
 Are you direct port or spray in the intake?
Would you mind sharing the lengths and sizes of house you came up with if you are not direct port ? I just bought a snow stage 2 and have heard not so great things about the hoses. I'd like to replace them.
AJPTurbo FTW
2015 SHO PP
Air raid intake, 3bar, OBX catless downpipes, 160tstat 2. Electric exhaust cutouts, MSD ignition coil, hot pipes with Tial BOV, AJP Turbo wastegate regulator mod.
For now...
Pending install. Snow stage
ddlopes
Quote from: BoostfoSHO on November 13, 2017, 09:14:03 AM
I inject my meth through 2 nozzles into the hot pipes. The length of your meth lines depend on the locations of your solenoids and nozzles. You'll have to measure that out to determine the length of your meth lines. But I would highly recommend Prometh lines... Good luck with the install!!!
TopherSho
If you run more than 51% meth.  you will need new lines each year according to snows own support.   so replacing the lines with braided is perfect.
however the pump is another issue.  did you get the A4n kit?  if not you will still have to use push\pulls on the pump as the inserts are not replaceable according to Snow support when i called them ..
Best 0-60 public road 4.35s
BoostfoSHO
I haven't gotten the kit yet. I bought it from someone who sold the car before they even opened the box. Picked it up for $300
Its the stage 2 I'm very new to all this so hopefully I don't blow up my car. I just got it back from the dealership after a month for a bad RDU they replaced the whole rear assembly. So far I got the LMS tuner, air raid intake, 3bar, t stat, sparkplugs from gear head and a muffler delete. Nothing installed yet but waiting in the garage.
AJPTurbo FTW
2015 SHO PP
For now...
